2011 Dodge 3.6 Pentastar Idle Issues
- Sketchmo
I am new to the website but have enjoyed watching all the Scanner Danner You Tube Vids. I am more of a mechanical versus electronic guy but wanting to learn.
I have a 2011 Dodge Durango 2WD Citadel 3.6 Pentastar engine. I have 244,00 miles on the vehicle and I am the original owner.
The engine has been well maintained for all of it’s life with oil changes and tuneups as specified. I started to get the CEL at 240K so I had new plugs, coils installed by a local mechanic and within days the CEL returned. The mechanic said he was not responsible for the CEL so I took over the project myself.
I checked the codes and it had 301, 305 codes so I checked the plugs and found out the mechanic used China plugs. After watching a Scanner Danner vid about the same issue on this vehicle I switched them out to the recommended Champion plugs and it ran great …for a day.
Then the codes 300, 301, 303, 305 appeared. Since I only had a basic BlueDriver code reader I went deeper into the motor and became a parts changer. This 2011 engine was known to have lifter needle bearing failures causing ticking issues. Based upon this I opted to open up the valve covers and replaced ALL of the lifters and rocker arms. I had read that these type of mechanical issues could cause the codes so it seemed like a reasonable exercise. While I had it opened up I did a Cylinder leakage test that came out with no problems on ALL cylinders.
Now it’s all back together and the same 301, 303, 305 codes continue to show up. I checked the fuel pressure and it says it is within spec. There is no vacuum leak and the manifold pressure is at 13.3 inHg so I don’t think I have any leaks.
I am at wits end and cannot determine where else to look to fix the issue. I have a multimeter at my disposal but that this it.
I was curious if I should have done a relearn on the crank/ cams after i took it all apart. Any other suggestions would be appreciated. I hate CEL lights!
Thanks
Sketchmo
- Hardtopdr2
- Thank you received: 150
- juergen.scholl
- Active partschanger
- Thank you received: 462
- Sketchmo
My guess it that I am having bigger issues with the computer but I am just a shade tree guy. Thanks for your input as always!
I agree with Juergen about the Freeze Frame data. That'll give us a much better idea of when the misfire is happening, which can help you shorten the list of suspects.
Since you have a BlueDriver, it'd also be nice to see the Mode $06 misfire counts to see how badly #1, #3 and #5 are misfiring. TID $83 if I remember right.
Speaking of 1-3-5, it just so happens that all three are on the same bank. :blink: :
That *might* indicate a bank one problem. Cam timing, plugged cat, like that.
I tested the Intake Air Temps via voltmeter back pinning the wiring and it read at 3.75 volts. Based upon SD vids it said the reading for a VW should have been at 5 volts. How can I find the voltage for this Dodge?
What SD said about 5V is true if the temp sensor is disconnected, as a way to check the computer and signal wire integrity. With the sensor connected, the voltage will be lower than 5V because the temp sensor is doing its job as a resistive short to ground.
- Sketchmo
Here is the data from the Code 6 readings on the Blue Driver during a cold start/ warmup. The CEL came on and identified a P0300 misfire. As you will see on the data I have misfires all on the right bank with the biggest problem being cylinder #5.
FYI I have all new Coils and new Champion plugs on all cylinders. I also had the Cats replaced a month ago along with the 02 sensors on both sides of the Cats. Also I had run a leak down test on ALL cylinders and there is virtually no difference on all 6 cylinders. Here were the readings.
Cylinder Pressure Test - PSI
1 - 80/79
2 - 80/79
3 - 80/78
4 - 80/79
5 - 80/76
6 - 80/80
If there is any other tests I can run and share on the BlueDriver let me know. See the attached image of the last scan.
A2 = Cylinder 1
A4 = Cylinder 3
A6 = Cylinder 5
Thanks again for your input!
- Sketchmo
I definitely agree that #5 is the biggest offender. Higher current drive cycle and EWMA counts than anyone else. I know you're getting multiple codes and multiple misfire counts, but I'd still suggest attacking #5 directly. It's going to be the easiest misfire to reproduce, and isn't obscured by the intake in this application.
I see that you've done a cylinder leakdown test, which is excellent.
- Dtnel
- Thank you received: 67
This could help isolate if the issue follows or not.
- Sketchmo
On some of the research I have found it says the pressure on these V6 Dodge 3.6 Pentastar should be between 125-90LBS.
Again since the engine has 245K miles I guess that 90 isn’t that bad.
I would have run the check on cylinders 2,6 & 6 but they are all covered by the intake manifolds that require a LOT of wrenching to get to.
Switching coil on #5 with another backup coil that was “new” a month ago that the other mechanic placed in the vehicle.
Wondering where to go to next?
Thanks for your continued patience and suggestions!
- Sketchmo
THANKS
- Sketchmo
- Sketchmo
- Matt T
- Thank you received: 276
Sorry ignore that last image.
It's actually kinda interesting. A2 0C and A6 0C are unchanged between it and the later image. And A4 0C has only gone up a bit.
