Toyota Avensis 1zz-fe 1.8l 2002 misfire p0304
  • toyotaproblem
  • toyotaproblem's Avatar Topic Author
4 years 9 months ago #53783 by toyotaproblem
Toyota Avensis 1zz-fe 1.8l 2002 misfire p0304 was created by toyotaproblem
Hi,
I have issue with my toyota and I have done almost everyting and we cant figured out that is the problem with that one cylider misfire p0304.
What I have done so far is:
- Changed all sparkplugs twice first bosch and later NGK
- New coil bosch and I have tried with other cylinder coils. Spark is strong and bright when the plug is in the coil, out of the cylinder
- I have tested and measured all 4 coil wires and every one of them in all cylinder gives same result. Continuity to ECM tested
- O2 sensor (oe-quality) tested and I have tried with new one on block 1. Car gave me some point p0172 code which is rich mixture code. That code havent come again.
- I have changed fuel injectors from other cylinder to cylinder number 4 but problem doesnt follow
- fuel injector wiring tested and all gives same ohms 14.2 and continuity to ecm tested. Grond is also good
- Fuel pressure is 3.2bar/46psi
- compression test good about 160psi all cylinders
- leakage test ok all cylinders
- cam sensor test gave me AC 0.8-1v. ohms 1150. Continuity to ECM tested
- New airfilter
- With new MAF-sensor tested. No effect
- Intake leak tested with break cleaner. No effect to running
With bosch obd reader I have noticed that misfiring goes in cycles. Misfires rices from 0 to 100 and back to 0 and again to 100. If I pull cam sensor pug out its stays on 10 misfires.
Where I shoud look next?
Thank you all ready.
4 years 9 months ago #53784 by Tyler
When does your misfire occur? At idle? While driving down the road? All the time?
If it's a constant misfire, or if it misfires at idle, does a power balance test confirm that #4 is in fact misfiring?
If you have it available, what does the Freeze Frame show for the P0304?
  • toyotaproblem
4 years 9 months ago #53802 by toyotaproblem
Replied by toyotaproblem on topic Toyota Avensis 1zz-fe 1.8l 2002 misfire p0304
Misfire occur all the time. If I unplug the coil wiring car to running in any cylinder. If I unplug fuel injector wiring nothing happens at cylinder 4. For other cylinder I notice difference. Spark plug gets wet if coil is out and plug in the cylinder. So its getting fuel. Also I hear clickin noise for all cylinders.
Freeze frame data shows misfires cylinder 4. Also noticed air fuel mixture is richer at o2 sensor bank 1.
  • toyotaproblem
4 years 9 months ago #53874 by toyotaproblem
I tried with new cam sensor no effect... Can be ECM issue?
4 years 9 months ago - 4 years 9 months ago #53877 by juergen.scholl
Replied by juergen.scholl on topic Toyota Avensis 1zz-fe 1.8l 2002 misfire p0304
If the ecm provides injector pulse and spark for the missing cylinder I wouldn't be too concerned about it at this point. At this point you may want to take running compression readings, at idle and snap throttle, one on a good cylinder and one on the offending one. If you had an oscilloscope you could do other, quicker measurements though.
Last edit: 4 years 9 months ago by juergen.scholl.
  • toyotaproblem
4 years 9 months ago #53910 by toyotaproblem
I am started to be desperate now. Comperssion seems to be good and second leak test was same than before. I also cheaked timing and that was also good.
I double cheaked continuity to ECM from coil, fuel injector and cam sensor. Everyting was good. Also tried with other crankshaft sensor and also no effect on that one....
4 years 9 months ago #53914 by juergen.scholl
Did you do a running compression test?
