Mitsubishi Outlander 2007 3.0 VRX v6
  • Devron
  • Devron's Avatar Topic Author
4 years 9 months ago #53951 by Devron
Mitsubishi Outlander 2007 3.0 VRX v6 was created by Devron
Hello I have had a crank sensor code P0335 show up. I have removed the sensor and test the resistance between ground and signal and get around 20M ohms. Does this sound correct as I think it seems very high ?
Cheers
4 years 9 months ago #53966 by oneel998
Replied by oneel998 on topic Mitsubishi Outlander 2007 3.0 VRX v6
seems high to me. seems open circuit. no help on alldata or identifx. if you verify wiring is okay. i THINK, you can plug the sensor up, and run a metal objector across the sensor rapidly and monitor scan data and see if rpm is picked up.
  • Devron
4 years 9 months ago #54007 by Devron
Replied by Devron on topic Mitsubishi Outlander 2007 3.0 VRX v6
Thanks for your reply I have tried what you said and it seems to be dropping the volts when a metal object is past across it. I'm not confident to replace it as over here its around $160, it could be a intermittent fault as the car runs fine once started but has a hard time starting and sometimes goes into limp mode if a restart it a few times it comes right. But when it trying to star it does sound like the timing is off. Strange as once running it goes perfect.
