Crank No Start…
  • davidlove47
  • davidlove47's Avatar Topic Author
4 years 9 months ago #53983 by davidlove47
Crank No Start… was created by davidlove47
Replaced the injectors the other day in my LB7 Duramax… truck ran fine for 2 days, then out of no where wouldn’t start back up. I pulled the injectors back out thinking I had a return line leaking as the truck is not reading but 1mpa of rail pressure. No leaks found, and when I got the truck back together it started right up and I shut it off after about 5 minutes, went inside to get cleaned up and get a bite to eat, came back out, truck won’t start again…. I’m at a total loss with it and started to get irritated with it. Please help!
4 years 9 months ago #53988 by oneel998
Replied by oneel998 on topic Crank No Start…
crank no start?
no crank no start?
have you used the forbidden go go juice to see if its fuel related?
does ecm comm with you truck the key on
  • davidlove47
4 years 9 months ago #53991 by davidlove47
Replied by davidlove47 on topic Crank No Start…
Yes, the engine cranks but does not start. I have gave it a sniff of starting fluid and it cranked up barely, but it did crank. But after I shut it off it doesn’t seem like it wants to start even with it
  • davidlove47
4 years 9 months ago #53992 by davidlove47
And yes the ecm communicates with my scan tool
4 years 9 months ago - 4 years 9 months ago #53993 by juergen.scholl
Replied by juergen.scholl on topic Crank No Start…
Do you get a rpm signal while cranking? Do yo have injector pulse during crank? Which scanner do you have and are there ANY unusual parameter values?
Last edit: 4 years 9 months ago by juergen.scholl.
4 years 9 months ago #53995 by oneel998
can you watch fuel pressure at all?
possible torn injector oring or you got dirt in the h.p. system
