2005 Dodge Grand Caravan 3.3L misfire diagnosis
- Scott1969
4 years 9 months ago #54032
by Scott1969
2005 Dodge Grand Caravan 3.3L misfire diagnosis was created by Scott1969
Hello, I have a 2005 grand caravan with the 3.3l v6. dead miss on cylinders 1 and 4. I back probed the coil connector signal wires to see if the firing
signals were there, all good except for the 1/4 tower. That should mean open circuit in the wiring or bad driver in the ECM. Correct? At this time i decided to send it to the local shop as it was dark outside and since i wasn't feeling well (covid 19 strikes again!). My wife picked up the van and they told her it had a bad coil pack! can the coil pack itself cause the signal from the ECM to not show up. Thanks for the help!
4 years 9 months ago #54035
Replied by Tyler on topic 2005 Dodge Grand Caravan 3.3L misfire diagnosis
Hey Scott1969! How exactly were you measuring the 1/4 coil signal at the coil pack? DMM, test light?
How the coil pack failed (if indeed the coil pack is the problem, and the only problem) will make a difference as to how it shows up in your testing. For example, if the 1/4 primary winding in the coil pack was electrically open, then it'll potentially change test light behavior.
Has the coil pack been replaced yet?
- Scott1969
4 years 9 months ago #54036
by Scott1969
Replied by Scott1969 on topic 2005 Dodge Grand Caravan 3.3L misfire diagnosis
Hello, thanks for the fast response. I was using a test light.
- Scott1969
4 years 9 months ago #54037
by Scott1969
And yes the coil pack has been replaced.
4 years 9 months ago #54045
Gotcha. So, to confirm, if you take your test light connected to B+ and touch a backprobe installed in the 1/4 coil control circuit with the engine running, the light does not pulse? Or, does the light stay on solid?
- Scott1969
4 years 9 months ago #54063
by Scott1969
Hello, The test light wasn't lit at all. I should have used a multimeter which would have shown me ghost voltage and i would have known there was an open primary winding. When i used the test light, it was connected to B- with no lighting of the bulb. But it would flash on the signal wires for the remaining good coils. Also i forgot to mention the test light was incandescent not led.
- Matt T
- Thank you received: 276
4 years 9 months ago #54069
by Matt T
That test told you either the primary was open/high resistance or the control was shorted to ground. Then switch the test light to B+ and if it flashes control is good. Lights up solid control is shorted.
Voltage checks with a DMM isn't a good test for primary circuits. A high resistance coil will test good and most of them ain't fast enough to check for control.
Replied by Matt T on topic 2005 Dodge Grand Caravan 3.3L misfire diagnosis
The following user(s) said Thank You: Dtnel
4 years 9 months ago #54075
Took the words right outta my mouth.
