Ecu case grounding
  • angelcoamo44
  • angelcoamo44's Avatar Topic Author
4 years 8 months ago #54193 by angelcoamo44
Ecu case grounding was created by angelcoamo44
I have a 1996 Mitsubishi montero 3.0l.....I would like to know why the engine light on the dashboard doesn't comes on.....Assuming the bulb is good, what other reasons can cause that the light wont turn on when I turn the key on....??? Does the ecu case has to be grounded...??....
4 years 8 months ago - 4 years 8 months ago #54199 by Noah
Replied by Noah on topic Ecu case grounding
You never answered anyone who tried to help you the last time you asked about this.
Not trying to be rude so please don't take offense.
To answer your question, you can easily check to see if the PCM case is grounded with a test light. If it was truly missing a ground, I expect there would be more trouble than one bulb not lighting.
www.scannerdanner.com/forum/post-your-re...-on-panel.html#53334
Last edit: 4 years 8 months ago by Noah.
The following user(s) said Thank You: angelcoamo44
  • angelcoamo44
4 years 8 months ago #54215 by angelcoamo44
Replied by angelcoamo44 on topic Ecu case grounding
Thanks a lot for all the help. I am very thankful for every advise I can get. I am trying to understand how to troubleshoot the electrical and electronic systems in a car, that's the reason I ask so many questions. This is an excellent forum and the moderators are very helpful. They're excellent. Also I want to thank everyone in this forum who gives me some kind of help. It is highly appreciated.
