Exterior light problem
  • autojoe
4 years 8 months ago #54425 by autojoe
Exterior light problem was created by autojoe
2000 dodge ram 1500 3.9. 4wd light on ip flashes when left turn signal is on left front bulb dim while flashing. Ground issue but both front share same ground and right front bulb bright and right turn signal does not make 4wd indicator flash inside. Also if remove left front turn signal bulb the 4wd indicator stops flashing. Any help would be greatly appreciated.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 8 months ago - 4 years 8 months ago #54426 by VegasJAK
Replied by VegasJAK on topic Exterior light problem
Correct on ground issue. 12v back feeding through right turn signal and finding ground through 4wd bulb. Check the common ground wire eyelet. One ground wire is broken inside eyelet.
Paul has a video on this on a Chrysler car can't recall the model. Ground wire bundle at eyelet had the broken ground inside eyelet.
Last edit: 4 years 8 months ago by VegasJAK.
  • autojoe
4 years 8 months ago #54429 by autojoe
Replied by autojoe on topic Exterior light problem
It's the left turn signal dim. Thank you for your advice. Appreciate it.
  • VegasJAK
  • VegasJAK's Avatar
4 years 8 months ago #54431 by VegasJAK
The short will be on the bright bulb ground.
  • autojoe
4 years 8 months ago #54439 by autojoe
It will be on the right front? That will cause dim bulb on left front and 4wd indicator on dash to flash? Correct? Thanks
  • autojoe
4 years 8 months ago #54440 by autojoe
Why is the left turn signal bulb dim?
4 years 8 months ago - 4 years 8 months ago #54442 by Chad
Replied by Chad on topic Exterior light problem
I have to disagree with this.
But, I agree with this...
(RED=Edited by me.)
Correct on ground issue. 12v back feeding through [strike]right[/strike] LEFT turn signal and finding ground through 4wd bulb. Check the common ground wire eyelet. One ground wire is broken inside, OR BEFORE, eyelet.
Because the path to ground contains extra resistance, (i.e. 4WD light, and maybe more), to ground. It lacks a DIRECT path to ground.
Last edit: 4 years 8 months ago by Chad.
The following user(s) said Thank You: autojoe
  • autojoe
4 years 8 months ago #54444 by autojoe
Thanks Chad.... Scannerjohn replied that the short will be on the bright bulb ground which is the right bulb is bright and left bulb dim. Now you are saying that it is the left front bulb that is dim has a ground problem. Is that correct? Thanks.
4 years 8 months ago #54449 by Chad
Correct. I do not believe the problem is on the Right. I believe the problem is an open ground on the Left Bulb.
4wd light on ip flashes when left turn signal is on left front bulb dim while flashing...right front bulb bright and right turn signal does not make 4wd indicator flash inside.
It sounds, to me, like the right signal is working, as it should. It is the Left bulb that has an alternate path to ground.
4 years 8 months ago - 4 years 8 months ago #54451 by Chad
I would check for voltage on the ground of all the bulbs (mainly, the Left), at the socket while the left signal is on. Front and Rear.
  • VegasJAK
  • VegasJAK's Avatar
4 years 8 months ago #54458 by VegasJAK
Sorry for any confusion on this... Does the right turn signal flash brighter than normal? and are the turns and parking lights contained in a single bulb?
Please keep me posted in what you find. I do not disagree with Chad, just interpreting thing differently.
  • autojoe
4 years 8 months ago #54459 by autojoe
I thought both was saying same thing. Right front Normal flashing and brightness. Let front dim but flash fast even on ip.
4 years 8 months ago #54463 by juergen.scholl
Replied by juergen.scholl on topic Exterior light problem
One of my all time favorites on the matter.
  • VegasJAK
  • VegasJAK's Avatar
4 years 8 months ago - 4 years 8 months ago #54511 by VegasJAK
Did you find the short?
Is that ground terminal located under the window washer bottle.
Really good video:) Thanks Juergen.
  • autojoe
4 years 8 months ago #54512 by autojoe
Thanks I will find out next time see vehicle. Will keep you posted.
