Crank no start -- MAF ?
  • Andy.MacFadyen
9 years 7 months ago #8186 by Andy.MacFadyen
Crank no start -- MAF ? was created by Andy.MacFadyen
Has anybody seen a crank no start due to a MAF issue ? I have never seen one but the Nissan Altima crank no start thread set me wondering.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
9 years 7 months ago #8187 by ScannerDanner
Replied by ScannerDanner on topic Crank no start -- MAF ?
On the older Vane Airflow Meters, yes but you would get a start, run, stall symptom. (Fuel pump cut off switch was internal to the VAF).
Can't recall ever seeing one cause a no start.
Don't be a parts changer!
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
9 years 7 months ago #8191 by cheryl hartkorn
Replied by cheryl hartkorn on topic Crank no start -- MAF ?
yes!! check this out
this guy has a good channel
9 years 7 months ago #8194 by Tyler
Replied by Tyler on topic Crank no start -- MAF ?
I've seen this on a Pathfinder, where a bug had jammed itself into the sensor. It had injector pulse, but the pulse width was so short that the engine only coughed and sputtered occasionally during cranking.
9 years 7 months ago #8202 by Steve83
Replied by Steve83 on topic Crank no start -- MAF ?
Yep had the same on a Jaguar S Type, would start but immediately cut out
Started and ran ok with MAF disconnected, found what looked like wasp jammed in the sensor
