Ford P0642
- Big GFK
4 years 7 months ago #55229
by Big GFK
Ford P0642 was created by Big GFK
Have an 08 F150 5.4 , crank no start with a P0642, little more advanced than my knowledge. I understand this is a 5v reference issue , looking for any tips or commonality with this particular code . Had 10 yrs a Ford dealer , never seen this particular issue - 25 yr total tech
4 years 7 months ago #55248
Replied by Tyler on topic Ford P0642
If you clear this code, does it come back immediately? Or, does it require idle time/test drive?
I'd suggest checking the easily accessible 5V reference sensors under the hood for 5V with a multimeter, KOEO. The FRPT and the TPS are out in the open, if I remember right. Finding 5V would suggest this isn't a hard fault. Finding less than 5V would suggest a hard fault. Start unplugging sensor and monitor the 5V circuit to pull back up.
- Paul P.
- Thank you received: 195
4 years 7 months ago - 4 years 7 months ago #55250
by Paul P.
Never stop Learning.
Replied by Paul P. on topic Ford P0642
It is a 5v VREF circuit low fault.
The sensors on this circuit are APP, FTP, PSPT, FRPT.
A good strategy might be to locate the VREF at the PCM and start unplugging sensors until the 5v comes back. (This assumes a good PCM for now)
If it comes back, a sensor may be bad. ( or a short to ground still)
If it doesn't come back, check for a short to ground, unplug the PCM put a test light to B+ on the VREF(harness side), is it LIT? If no, check the PCM itself for 5V. If it is lit, you have a short to ground somewhere in those 4 sensor circuits.
Last edit: 4 years 7 months ago by Paul P..
- Big GFK
4 years 7 months ago #55265
by Big GFK
Replied by Big GFK on topic Ford P0642
Yes it comes back immediately, that's the only code I have currently, replaced FRP sensor , it was literally falling apart , swapped throttle body with another us to excessive carbon buildup, excessive.
4 years 7 months ago #55272
That makes things easier.
Check for 5V at the FRPT and the TPS, KOEO. Let us know if it's there or if it's missing.
