2006 Chevy silverado 5.3 low idle and lean codes
  • youngmarlin
  • youngmarlin's Avatar Topic Author
4 years 7 months ago #55395 by youngmarlin
The truck has lean codes for both banks. Runs lean cold and hot. Also the idle is at about 550-600 RPM. Checked fuel pressure and has 60 PSI and doesnt drop at all on a snap throttle. Did an injector balance test and all injectors dropped from 57 down to 40 PSI across the board. O2 sensors respond to lean and rich conditions by disconnecting brake booster and spraying brake clean into the intake. all biased voltages are 447 mv before starting vehicle but as soon as they start heating up voltages drop down to 50-100mv. They have also been replaced because of prior O2 codes that have not returned since replacement. Performed a volumetric efficiency test and was 65%. Replaced MAF sensor because everything else seemed fine with a New Bluestreak brand from Autozone and did not change anything. Truck does not show any lack of power while driving it will burn the back tire off if you slam the accelerator. Also checked the purge valve for sticking open and works normal. Oil change was done as well. When raising the RPM the fuel trims go from 27+ on both banks up to 30+. We also cleaned the throttle body for the idle problem and did fix the low idle. This truck does not have a ICV and does not have a relearn function on the Snap Zeus scan tool. I am at a loss on what else to check. I figured if it was a mechanical problem I would have a loss of power but it runs normal while driving just idle low and runs lean on both banks per scan data.
4 years 7 months ago #55397 by Hardtopdr2
Replied by Hardtopdr2 on topic 2006 Chevy silverado 5.3 low idle and lean codes
The 5.3 exhaust manifolds have a tendency of breaking the bolt heads off. Look at the manifolds and check bolts and flanges.
  • youngmarlin
4 years 7 months ago #55401 by youngmarlin
Replied by youngmarlin on topic 2006 Chevy silverado 5.3 low idle and lean codes
Yes it did have a broken bolt on each side but you couldnt even hear an exhaust leak even when cold. And 30%+ seems way too high for an exhaust leak you cant even hear. I have seen these trucks with bigger exhaust leaks before and fuel trim were not any higher than 10 percent, 15 at max.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 7 months ago #55424 by VegasJAK
You could still have a vacuum leak along with fuel delivery problem. 5.3's are known for intake leaks. Worth doing smoke test and water on intake runners.
Voltage check on injectors with a DSO is very helpful but not all have the equipment.
If possible, pinch off fuel return line and watch for trim correction.
  • youngmarlin
4 years 7 months ago #55425 by youngmarlin
Fuel pressure was steady at 60 PSI even upon snap throttle, indicating no sign of a fuel delivery problem. Also performed an injector balance test and all had 57 PSI to 40 PSI drop across the board. We used a smoke machine no leaks were indicated. Also tried brake clean around the manifold and no change in fuel trim or the O2 sensor voltages.
  • VegasJAK
  • VegasJAK's Avatar
4 years 7 months ago #55430 by VegasJAK
Do you have any freeze frame data on the P0171/174? If not, clear codes and restart engine from cold. Let's see where the codes set.
4 years 7 months ago #55435 by Cheryl
What does the alcohol content say in the scanner? Check for fuel contamination?
  • youngmarlin
4 years 7 months ago #55449 by youngmarlin
Im not sure how freeze frame would help its not intermittent. It runs lean from the beginning of start up and even while at operating temperature.
  • youngmarlin
4 years 7 months ago #55450 by youngmarlin
I tried looking for this data PID on 2 different scan tools and was not an option on this truck.
4 years 7 months ago #55452 by Cheryl
It might not be flex fuel. Does the truck use e85
4 years 7 months ago - 4 years 7 months ago #55454 by juergen.scholl
Replied by juergen.scholl on topic 2006 Chevy silverado 5.3 low idle and lean codes
If this reply refers to the alcohol content you couldn't find: Get a fuel sample out of the tank. Put x volume of it together with y volume of water into a graduated measuring cup. There will be a distinctive line between the two different fluids. Then agitate the fluids and let them settle. Any alcohol in the fuel will rise the "water level" mark. Based on this you can calculate the percentage of alcohol in the fuel.
Otherwise you may want to run it with fresh, known good gas from an external source. As the fuel trims are skewed all the time you could test it even at idle in park.
Last edit: 4 years 7 months ago by juergen.scholl.
  • youngmarlin
4 years 7 months ago #55458 by youngmarlin
This vehicle was an engine VIN code T which showed not flex fuel.
4 years 7 months ago - 4 years 7 months ago #55465 by juergen.scholl
If someone was to put E85 into it the pcm wouldn't know and as a result LEAN CODES will show. 8-;
  • youngmarlin
4 years 6 months ago #55646 by youngmarlin
The fix ended up being the MAF sensor they purchased a new OEM and it fixed the issue. This will be the last time i use an aftermarket MAF new or not on any vehicle.
  • VegasJAK
  • VegasJAK's Avatar
4 years 6 months ago #55651 by VegasJAK
Symptoms sure pointed to MAF but it was replaced... didn't recommend testing MAF voltages as you seem very apt and thorough. Lately have seen many many cases of aftermarket parts not compatible. Chrysler, Nissan and GM. What made you go for the MAF a second time?
  • youngmarlin
4 years 6 months ago #55652 by youngmarlin
It was a used car dealerships vehicle. He just took it to another shop because I communicated that I had no other options on what to check. And the other shop replaced the MAF and the idle is normal and fuel trim are back to normal range
