1998 mustang GT mass air P0102 code
- Clay24
4 years 7 months ago #55532
by Clay24
1998 mustang GT mass air P0102 code was created by Clay24
I have a 1998 Mustang GT that is getting a map air sensor low voltage code oh, p0102. When I hook the scanner up there is no voltage reading on the mass aircoming but if I hook up a voltmeter to the two signal wires at the sensor, I get a voltage reading. I also get a voltage reading if I check those sensor wires at the computer. The wires check out ok for continuity so I can only assume the the computer is bad because I have data, voltage, going back to the computer but it's just not seeing it. Am I correct in that assumption or am I missing something?
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
4 years 7 months ago #55543
by VegasJAK
Replied by VegasJAK on topic 1998 mustang GT mass air P0102 code
I believe you're looking at the MAF/IAT. How many wires are there? What voltage readings did you get?
- Clay24
4 years 7 months ago #55544
by Clay24
Replied by Clay24 on topic 1998 mustang GT mass air P0102 code
The sensor has 4 wires. Key on engine running I got red wire 12v. Black was ground. Voltage reading across the LB/R and T/LB was right around 1v at idle. If I rotate the throttle I would see the voltage go up on the meter. The scan tool showed 0v
- VegasJAK
4 years 7 months ago #55545
by VegasJAK
Just a MAF then. 12v power and ground. Signal and signal ground. There is only one signal wire, but two grounds.
I would test again. With meter black lead to ground, check voltage on each wire at sensor and ecm.
ECM's are pretty hardy, so unless someone or something shorted the 12v into the signal wire the problem should be an open signal wire. Make sure the ecm pins are good, no corrosion and securely connected. WOT voltage on MAF signal should be 4v.
- Clay24
4 years 7 months ago #55546
by Clay24
I replaced the MAF from a running car and no change. I'll double check tomorrow but both signal wires ohm out fine back to the PCM. Does the PCM look at the voltage across those two wires or just one to ground?
- VegasJAK
4 years 7 months ago #55547
by VegasJAK
Its only one signal wire for the MAF and that is what the ECM looks at voltage wise. It wants to see .09v 1v at idle and up to 4v at WOT on that signal wire. If you're getting voltage at the sensor but not the ECM that's where you have to concentrate, the wire between the two. You mentioned 0v at the ECM make sure you are looking at the MAF signal not the MAF signal ground. The scantool not showing MAF signal voltage is the problem. ECM's are expensive and really no way to test them so everyone hates calling an ECM as bad. Consider if you put in a new ECM and the problem is wiring, you could blow out the new ECM. Voltage testing is more reliable than Ohm testing. The voltages you want to see are 12v on power, .100mv on grounds and 1 to 4v on the signal at the sensor and the ECM.
The following user(s) said Thank You: Clay24
- Clay24
4 years 7 months ago #55549
by Clay24
With the car running, I back probed the ECM connector and measured the voltage the voltage across the LB/R and T/LB and got 1.0V at idle.
I had the Forscan software running at the same time and the MAF V_V was showing 0.0V. eventually the software will show a MAF fault, check engine light will come on (p0102) and engine will die.
A little back story......This ECM is a replacement ECM because the original one had no control signal to the coils and car would not start. Purchased a "remanufactured" one, car started and ran but ran terrible and this is where I'm at.
- VegasJAK
4 years 7 months ago #55551
by VegasJAK
Remanufactured. You got a bad one. Return it.
- Clay24
4 years 6 months ago #56010
by Clay24
UPDATE: I got a replacement computer, plugged it in and it worked. Thanks for all your input and guidance.
