Should engine be at temperature before doing VANOS reset/relearn?
- JeffBirt
- Thank you received: 34
4 years 6 months ago #55648
by JeffBirt
Should engine be at temperature before doing VANOS reset/relearn? was created by JeffBirt
I'm sure this is a silly question but as I only have access to Mitchell DIY and can't seem to find it covered there I thought I would ask. I have a 2011 Mini Countryman S with N18 engine. I recently replaced the exhaust side VANOS solenoid and did the reset/relearn procedures. I was guessing that the engine should be up to operating temperature before the reset/relearn but could not find a reference to say one way or the other.
Thanks for any insight you can provide.
- JeffBirt
4 years 6 months ago #55687
by JeffBirt
Replied by JeffBirt on topic Should engine be at temperature before doing VANOS reset/relearn?
Someone was able to tell me that their SnapOn scanner service info says the engine should be at least 60C before the reset/relearn.
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
4 years 6 months ago #55690
by VegasJAK
Replied by VegasJAK on topic Should engine be at temperature before doing VANOS reset/relearn?
No question should go unanswered. Thank you Jeff for the info..
ps; I had to Google VANOS, my farfegnugen is terrible. That one got me.:blink:
- JeffBirt
4 years 6 months ago #56006
by JeffBirt
As it happens I had the need to do the CAM limits relearn with the engine cold yesterday. I was testing a software update for this functionality for the scan tool manufacturer two days ago and it did not go as planned.
They quickly fixed the software glitch and I did a relearn with the engine cold. It started OK but seemed to run ever so slightly lumpy. After driving a few miles to get the engine up to about 80C I did the relearn again and all was well. Started it from cold this morning and it drove perfectly.
Just FWIW in case anyone else gets into a similar situation.
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 6 months ago #56008
by juergen.scholl
Don't worry, one day, with the right car it will turn into ein kleines bisschen Fahrvergnügen :lol:
Replied by juergen.scholl on topic Should engine be at temperature before doing VANOS reset/relearn?
ps; I had to Google VANOS, my farfegnugen is terrible.:blink:
