89 bronco
  • Kevin p
  • Kevin p's Avatar Topic Author
4 years 6 months ago #55793 by Kevin p
89 bronco was created by Kevin p
This bronco cranks for 10 seconds before it even tries to start, once started it starts fine for hours. It has good fuel pressure and maintains, it has good injector pulse, starts with 2+2
4 years 6 months ago #55800 by Chad
Replied by Chad on topic 89 bronco
The next time you start it, turn the key on, but don't crank, or start it. Then turn the key back off. Turn the key back on. But, again, don't start it. Turn the key back off. Now, start it. If this helped, your fuel pump is allowing fuel to flow back through it, bleeding fuel pressure. Cycling the key, with out attempting to start it, cycles the fuel pump, and builds fuel pressure.
