2007 Ford Explorer
  • mzaayer
  • mzaayer's Avatar Topic Author
4 years 6 months ago #55836 by mzaayer
2007 Ford Explorer was created by mzaayer
Hello, I have a 2007 Ford Explorer with the 4.0L engine. I bought it from a dealer not running. The dealer had opened the PCM, so I ordered a remanufactured one. After a lengthy time I received the PCM and hooked it up and programmed the PATS, New keys. I have these two codes and I am at a point I can not get past. The codes are C2780-60 ECU in Manufacturer SUB-state and P0642 sensor reference voltage #A circuit low. I also am only getting 0.33 lbs of fuel rail pressure. If anyone can help me I would appreciate it.
Thank you,
Matthew Zaayer
4 years 6 months ago #55837 by Cheryl
Replied by Cheryl on topic 2007 Ford Explorer
You need to check the 5 volt references. Do you have a wiring diagram
The following user(s) said Thank You: mzaayer
  • mzaayer
4 years 6 months ago #55838 by mzaayer
Replied by mzaayer on topic 2007 Ford Explorer
I have checked some, I must admit I have not checked all. I do not have a good wiring diagram. I have figured there is an A and a B side but do not know which side is the A Side.
Thank you for your response.
Matthew
4 years 6 months ago #55841 by Cheryl
I’ll look tomorrow and let you know what sensors are on each
