Secondary ignition waveform
- Sanchezj3161
4 years 6 months ago #55843
by Sanchezj3161
Secondary ignition waveform was created by Sanchezj3161
I need help figuring out what this waveform means.
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 6 months ago #55844
by juergen.scholl
Replied by juergen.scholl on topic Secondary ignition waveform
Without the scaling and some information about the kind of ignition system it is not possible to make comprehensive, meaningful comments.....
Whatsoever, the yellow trace seems to be primary current and shows a clean cut off. The green voltage trace shows a lot of turbulance, the overall burntime seems to be 1 to 1.2 ms?? The coil does have some reserve capacity as indicated by the oscillations...
Are you familiar with the ignition scope part of your tool? What is the actual problem with this car?
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
4 years 6 months ago #55847
by VegasJAK
Replied by VegasJAK on topic Secondary ignition waveform
Short firing line with a higher kv spark and turbulence in the first half of the spark line IMO indicates external resistance. Spark occurring outside the cylinder.
- juergen.scholl
4 years 6 months ago - 4 years 6 months ago #55848
by juergen.scholl
Though there is critical information missing I can't determine that the spark is taking place out of the cylinder.Also a firing time of 1ms or 1.2 still may be in line.
More qualifying information needed to make a meaningful statement.... (if I had to I would guess a problem in the secondary, possibly spark plug)
Last edit: 4 years 6 months ago by juergen.scholl.
