Honda civic "low" idle
- bjørn.ali.stokman
- Thank you received: 5
4 years 6 months ago #55880
by bjørn.ali.stokman
Parts cannon first, then diag.
Honda civic "low" idle was created by bjørn.ali.stokman
Honda civic 1997 b16a2
Hello!
I was looking for some help on a idle issue.
Whenever I give i press the clutch in while driving, so it goes in neutral and I'm coasting. The RPMs drop to nearly 400rpms then bounces back up to 7-800 which is the normal idle.
Doesn't matter if it's warm og cold, does this if I'm standing still and I rev it and let it drop down, it also goes really low. Almost dies, but doesn't.
Any help regarding this would be appreciated, I myself is suspecting the IACV or maybe a bad alternator?
No DTC. Have access to some PIDS and a scope if necessary.
Hello!
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
4 years 6 months ago - 4 years 6 months ago #55883
by VegasJAK
Replied by VegasJAK on topic Honda civic "low" idle
Sounds like the dashpot/idle stop. If equipped check vacuum line.
btw, I'm not advising altering the idle stop in anyway only check that it's working
Last edit: 4 years 6 months ago by VegasJAK.
4 years 6 months ago - 4 years 6 months ago #55887
Replied by Andy.MacFadyen on topic Honda civic "low" idle
Not an unknown issue on Honda of this era usually just remove and clean the IACV and throttle body with carb cleaner and a toothbrush. Try this first before looking for anything more complicated.
ISTR Paul made a video on a similar Honda issue.
I would strongly advise not to alter the throttle idle stop.
Last edit: 4 years 6 months ago by Andy.MacFadyen.
- bjørn.ali.stokman
4 years 6 months ago #55894
Replied by bjørn.ali.stokman on topic Honda civic "low" idle
I will see if i can find any of ScannerDanners videos.
But i have to say, i took apart the IACV and it is clean as a whistle.
No weird fuel trims, nothing weird (to me atlest) under load.
Nothing to point me in any direction.
Im not sure where the idle stop is located on my car, I did adjust the bottom RPM to a higher level just so it wouldnt almost die when letting go of the gas after Acceleration, but that is only temporary, I want to treat the problem, not the symptom.
It still bounces of the bottom though, and idle drops when turning the wheel, enabling rear defroster and so on.
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 6 months ago #55895
by juergen.scholl
+1 (or 2...)
Replied by juergen.scholl on topic Honda civic "low" idle
+1 (or 2...)
- VegasJAK
4 years 6 months ago #55899
by VegasJAK
Did you make sure the shutter valve was rotating freely? You may have, just asking.
- bjørn.ali.stokman
4 years 6 months ago #55903
No, i dont have gaskets so didnt want to take it any further, but ill make sure to check that as soon as i get a gasket.
Time to create page: 0.367 seconds
