Reaching out to the masters... please help
- Indoblaze
4 years 6 months ago - 4 years 6 months ago #56034
by Indoblaze
Reaching out to the masters... please help was created by Indoblaze
2004 Audi A8 4.2l Quattro D3 ,No start ,no instrument cluster ,unable to locate 5v ref circuit getting ghost voltage reading very faint, checked all fuses, front left, front right, trunk left and right good 373,53,370,167 relays ohmed out ,Car is bricked, ( front left 1A switch illumination, front right 5A Engine Cu,15A fuel injectors, 30A Ignition coils)getting the ghost voltage , taking it to Audi Delership in not a option Towed it over there 1-25-2022 and just towed it back 4-18-2022 they mentioned three master Audi Mechanics couldn't figure it out, Wacked... Scanner Danner is my go to... Thank you guys soo much , got both schematics just can't seem to find the issue..
Last edit: 4 years 6 months ago by Indoblaze. Reason: Pics
- Tutti57
- Thank you received: 254
4 years 6 months ago #56118
by Tutti57
Replied by Tutti57 on topic Reaching out to the masters... please help
Assuming this is a no crank, no start? I'm not familiar with the network these use, but if you've got no communication to modules, I'd start by checking for 60ohms between can high and low at the dlc.
When you say dim, ghost voltage, where are you taking and seeing this reading?
Do you have 5v on any accessible sensor?
- Indoblaze
4 years 4 months ago - 4 years 4 months ago #56687
by Indoblaze
Replied by Indoblaze on topic Reaching out to the masters... please help
Thank you so much for reaching out...ghost voltage was at. Number 9 pin on ignition module....trying to figure out this terminal code... check all leads changed ignition switch.. relays , fuses... no sign of damaged wire harness.... still no instrument cluster coming up. Any information would help..
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 11 31 15 16 17 19 1D 25 28 34 36
37 38 42 46 47 4F 52 53 55 56 61 62 72 75 76
VIN: WAUML44E14N022231 Mileage: 234950km-145991miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Not registered 0001
11-Engine II -- Status: Cannot be reached 1100
31-Engine other -- Status: Cannot be reached 1100
15-Airbags -- Status: Not registered 0001
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Cannot be reached 1100
34-Level Control -- Status: Not registered 0011
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Not registered 0011
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: Not registered 0001
76-Park Assist -- Status: Not registered 0011
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0D2535957
Coding: 0007773
Shop #: WSC 02313 067 57207
VCID: 1F1BEE580BB941B3D65-804A
VINID: 9D195D7041150447800820830498E11D23
6 Faults Found:
18058 - Powertrain Data Bus
P1650 - 008 - Missing Message from Instrument Cluster
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0031749
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2411E1B422DF626B8B7-8070
3 Faults Found:
18290 - Powertrain Data Bus
P1882 - 000 - Missing Message from Electric Parking Brake Controller
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 118.0
Temperature: 35.0°C
T.B. Angle: 0.0°
Voltage: 11.68 V
18271 - Powertrain Data Bus
P1863 - 000 - Missing Message from Steering Angle Sensor
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 118.0
Temperature: 35.0°C
T.B. Angle: 0.0°
Voltage: 11.68 V
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 118.0
Temperature: 35.0°C
T.B. Angle: 0.0°
Voltage: 11.68 V
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D2535957
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58E985442E17F68BD7F-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
00576 - Terminal 15
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 148
Mileage: 234944 km
Time Indication: 0
Date: 2003.11.21
Time: 00:55:58
01176 - Key
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 255
Mileage: 234944 km
Time Indication: 0
Date: 2003.11.21
Time: 01:11:32
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 2313E2A827D16553F2D-8076
1 Fault Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2022.02.16
Time: 10:32:50
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 731 N HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 346BL047510539
Coding: 0000003
Shop #: WSC 12345 111 45725
VCID: 2C0109944A0FAA2B437-8078
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023587
Subsystem 3 - Serial number: 0131.10.060000000100010029ÿ
Subsystem 4 - Serial number: 010029ÿ
2 Faults Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 178306 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
02257 - Remote Control Receiver
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:05
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0300
Revision: 00000024 Serial number: 00000000038963
Coding: 1085761
VCID: 1B63DA481FA15D933AD-804E
3 Faults Found:
00713 - Centre Left Vent Positioning Motor (V110)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:10
Freeze Frame:
Voltage: 11.60 V
Temperature: 40.0°C
(no units): 203.0
(no units): 200.0
Temperature: 34.0°C
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:13
Freeze Frame:
Bin. Bits: 00011111
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:13
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBD1035277
Shop #: WSC 00000 000 00000
VCID: 1C61D9541AAF5AAB337-8048
No fault code found.
Address 11: Engine II
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: 6597BCB069655B635C9-8030
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D2005413
Coding: 0001600
Shop #: WSC 77827 127 263172
VCID: 5CE199545A2F1AABF37-8008
1 Fault Found:
000 - -
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:21
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 0500504213165F
Coding: 78FFC7DC0B2104
VCID: 2615FBBC54E3907B953-8072
6 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:13
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:13
01342 - Engine Control Module 2 (Slave 1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:18
02003 - Driver Identification Control Module (J589)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:18
00565 - Rear A/C Control Head (Climatronic) (E265)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:18
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:18
Address 1D: Driver Ident.
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
2 Faults Found:
00576 - Terminal 15
006 - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 148
Mileage: 234944 km
Time Indication: 0
Date: 2003.11.21
Time: 00:55:58
01176 - Key
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 255
Mileage: 234944 km
Time Indication: 0
Date: 2003.11.21
Time: 01:11:32
Address 28: HVAC, Rear
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2517FCB029E59B639C9-8070
8 Faults Found:
00807 - Suspension Strut Valve; Rear Left (N150)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 11101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.20
Time: 23:59:02
00808 - Suspension Strut Valve; Rear Right (N151)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:25
00805 - Suspension Strut Valve; Left Front (N148)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:26
00806 - Suspension Strut Valve; Front Right (N149)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:26
01397 - Venting Solenoid for Level Control (N111)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:26
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:27
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:27
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4071522
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2022.02.16
Time: 10:32:50
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H43 0570
Revision: 00000000 Serial number: 355CO047516454
VCID: 35372CF09945EBE32C9-8060
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:28:31
Freeze Frame:
Bin. Bits: 0100
Address 38: Roof Electronics
Cannot be reached
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM007 0110
Coding: 0028196
VCID: 5EE5935C4C3308BB9D3-800A
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040402230111
Coding: 0065086
VCID: 270BF6B853E98973AE5-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 32
Reset counter: 148
Mileage: 234957 km
Time Indication: 0
Date: 2022.02.16
Time: 10:32:50
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 148
Mileage: 180748 km
Time Indication: 0
Date: 2003.10.08
Time: 02:43:50
Freeze Frame:
Fault Priority: 3
Fault Frequency: 28
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.10
Time: 23:47:13
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 26
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.10
Time: 23:47:14
Address 47: Sound System Labels: None
Part No SW: 4E0 910 224 C HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0470
Revision: Dev_D01 Serial number: 00000000000173
Coding: 0000008
Shop #: WSC 12345 111 45799
VCID: 1E65D35C0CB348BBDD3-804A
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 148
Mileage: 227538 km
Time Indication: 0
Date: 2004.03.17
Time: 15:27:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 205298 km
Time Indication: 0
Date: 2018.12.20
Time: 17:26:42
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000035530
Coding: 0010111
Shop #: WSC 11111 111 45799
4 Faults Found:
02268 - Switch to Deploy Display Unit
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 15
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2003.10.27
Time: 03:26:00
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Priority: 4
Fault Frequency: 17
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2003.10.27
Time: 03:28:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2003.11.20
Time: 23:55:00
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 18
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028196
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 629DA7AC784B2C5BB9B-8036
2 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 234952 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 234952 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:45
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304CM047582167
Coding: 0000002
VCID: 313F18E06D2DC7C3701-8064
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000001376276
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 2512192105
Coding: 303030393135313035414B56413032353132313932313035
Shop #: WSC 22308 444 00872
4 Faults Found:
02276 - Quiescent Current Stage 5
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:49
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:26:18
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:26:51
02273 - Quiescent Current Stage 2
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.20
Time: 23:58:44
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028196
VCID: 5DE79450413513A3849-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028196
1 Fault Found:
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 234944 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:40
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3008587
Coding: 0000005
VCID: 6099ADA476573E4BAFF-513C
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730405500663
Coding: 0001208
VCID: 211FE8A03DCD7743E01-8074
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:53
End
(Elapsed Time: 02:03, VBatt start/end: 12.6V/12.6V)
This is what is showing ...
Coding: 0007773
6 Faults Found:
Coding: 0000002
3 Faults Found:
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 118.0
Temperature: 35.0°C
T.B. Angle: 0.0°
Voltage: 11.68 V
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 118.0
Temperature: 35.0°C
T.B. Angle: 0.0°
Voltage: 11.68 V
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 118.0
Temperature: 35.0°C
T.B. Angle: 0.0°
Voltage: 11.68 V
Cannot be reached
Coding: 0263168
Component: ELV XXXX
2 Faults Found:
00576 - Terminal 15
006 - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 148
Mileage: 234944 km
Time Indication: 0
Date: 2003.11.21
Time: 00:55:58
01176 - Key
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 255
Mileage: 234944 km
Time Indication: 0
Date: 2003.11.21
Time: 01:11:32
Coding: 3940448
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2022.02.16
Time: 10:32:50
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 178306 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:05
Coding: 1085761
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:10
Freeze Frame:
Voltage: 11.60 V
Temperature: 40.0°C
(no units): 203.0
(no units): 200.0
Temperature: 34.0°C
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:13
Freeze Frame:
Bin. Bits: 00011111
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:13
Cannot be reached
Cannot be reached
Coding: 0530707
Coding: 0012241
Coding: 0001600
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:21
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:13
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:13
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:18
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.21
Time: 16:15:18
Cannot be reached
Coding: 0263168
Component: ELV XXXX
2 Faults Found:
00576 - Terminal 15
006 - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 148
Mileage: 234944 km
Time Indication: 0
Date: 2003.11.21
Time: 00:55:58
01176 - Key
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 255
Mileage: 234944 km
Time Indication: 0
Date: 2003.11.21
Time: 01:11:32
Cannot be reached
Coding: 0015510
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.20
Time: 23:59:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:27
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:27
Coding: 4071522
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2022.02.16
Time: 10:32:50
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:28:31
Freeze Frame:
Bin. Bits: 0100
Cannot be reached
Coding: 0028196
Coding: 0065086
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 32
Reset counter: 148
Mileage: 234957 km
Time Indication: 0
Date: 2022.02.16
Time: 10:32:50
Freeze Frame:
Fault Priority: 3
Reset counter: 148
Mileage: 180748 km
Time Indication: 0
Date: 2003.10.08
Time: 02:43:50
Freeze Frame:
Fault Priority: 3
Fault Frequency: 28
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.10
Time: 23:47:13
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 26
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.10
Time: 23:47:14
Coding: 0000008
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 148
Mileage: 227538 km
Time Indication: 0
Date: 2004.03.17
Time: 15:27:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 205298 km
Time Indication: 0
Date: 2018.12.20
Time: 17:26:42
Coding: 0010111
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 15
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2003.10.27
Time: 03:26:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 17
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2003.10.27
Time: 03:28:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2003.11.20
Time: 23:55:00
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 18
Reset counter: 148
Mileage: 234956 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:00
Coding: 0028196
Cannot be reached
Coding: 0000001
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 234952 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 234952 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:45
Coding: 0000002
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:49
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:26:18
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:26:51
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 234958 km
Time Indication: 0
Date: 2003.11.20
Time: 23:58:44
Coding: 0028196
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 234944 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:40
Coding: 0000005
Coding: 0001208
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 148
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.27
Time: 03:25:53
End
Last edit: 4 years 4 months ago by Indoblaze.
The following user(s) said Thank You: Kman68
- Kman68
4 years 4 months ago #56688
by Kman68
Replied by Kman68 on topic Reaching out to the masters... please help
Not a master but the year make and model will probably be asked for. That many codes would lead me to pcm/ecm. I would do the basic checks starting at the ASD relay checking for power from your Ecm. But don’t know the vehicle but sure the pros here will want to know. Just be patient these guys are super busy but want to help
- Indoblaze
4 years 4 months ago #56690
by Indoblaze
2004 Audi A8 4.2l Quattro D3 BFM...
