P0300 2005 Chevrolet Tahoe 4.8
  • 209businessman
  • 209businessman's Avatar Topic Author
4 years 4 months ago #56635 by 209businessman
P0300 2005 Chevrolet Tahoe 4.8 was created by 209businessman
I have my 2005 Chevrolet Tahoe 4.8 started to throw the P0300 and I was watching the live data on my scan tool and it seems as the oxygen sensors are acting crazy especially bank 1 sensor 1.
  • 209businessman
4 years 4 months ago - 4 years 4 months ago #56636 by 209businessman
Replied by 209businessman on topic P0300 2005 Chevrolet Tahoe 4.8
Here’s the video
Last edit: 4 years 4 months ago by 209businessman.
4 years 4 months ago #56637 by Calear01
Replied by Calear01 on topic P0300 2005 Chevrolet Tahoe 4.8
Some common reason for this to happen is faulty. You can check this...
  • Vacuum leak
  • Engine timing off
  • Distributor failure
  • Faulty fuel injector
  • Low fuel pressure
  • crankshaft sensor defective
  • Leaking head gasket
4 years 4 months ago #56812 by 209man
Replied by 209man on topic P0300 2005 Chevrolet Tahoe 4.8
i was able to fix my issue. Thank you. It turned out to be a faulty ignition coil on cylinder #1, I used my new Zurich pro scanner to watch misfire data on all cylinders and cylinder #1 was misfiring, i swapped the coil over to cylinder #3 and put that coil on number 1 and now cylinder #3 was misfiring. I knew right away I had found my issue and went to buy a brand new ignition coil. No more misfiring. Don't be a parts changer guys lol.
4 years 4 months ago #56815 by MitchM
Replied by MitchM on topic P0300 2005 Chevrolet Tahoe 4.8
It is interesting that the OBDII did not ID a misfire specific to that cylinder —-Such as 0o301 —- and instead threw the p 0300 random misfire. I’m glad the old fashioned coil swap worked really well for you to cure this Misfire.
4 years 4 months ago #56826 by juergen.scholl
Replied by juergen.scholl on topic P0300 2005 Chevrolet Tahoe 4.8
You really don´t want to stay with a broken part, do you?:lol: :lol: :lol:
