Section 1: Universal Testing Methods pg8 Low Power
Are there any variables that would result in a rich upstream o2 reading @ WOT that is NOT a restricted exhaust?
- ScannerDanner
- Administrator
- Thank you received: 500
I have seen a shorted rotor on a distributor style ignition system cause the O2 to drop lean at WOT, thought for sure it was a fuel pressure problem because it only did it under load.
Don't be a parts changer!
That rotor must have been a fun diagnosis!
- Chriscoy
- Heavy duty truck technician / foreman/ parts guy/
- Thank you received: 6
Changing parts is easy, Troubleshooting is an art
Wild guess... leaking CFI?
- Chriscoy
In light of the recent discussion about fuel contamination, I guess that junk fuel could cause this, but would likely exhibit other symptoms.
- Chriscoy
I know it's kind of a weird question.
EDIT: Found 'em on ScanShare. Don't forget to hit 'Open PID List'
Here's a known good WOT run, Chevy 5.3L:
www.scanshare.io/share/PthKNw1SfUGJnZW7SEl4Og
And here's the same run with an exhaust cone stuffed in the intake tube:
www.scanshare.io/share/usHlQlFdnkiOTKEZYiTR8w
The giveaway is the MAP sensor showing vacuum in the intake while at WOT.
Looks like I can add "restricted Intake" to my notes on that page.
Thanks Tyler, Chris and Paul!
I read somewhere that California emissions engines came with intake runner "butterflies" while Fed engine didn't. Sure enough, he was sold a California engine, and used the intake that came with the replacement engine. Swapping the intakes fixed it.
About the ScanShare.io captures, yeah, isn't that crazy? I really wish more cars had MAP sensors after that experiment, lol.
Just thinking out loud, do you think the location of the restriction would be significant? As in, before the MAF, or after? The installed restriction in those captures was after the MAF, just not sure if a restriction before the MAF would have the same O2 behavior.
