[Fixed] A/C Repair
  • Charles Acosta
  • Charles Acosta's Avatar Topic Author
9 years 5 months ago - 9 years 4 months ago #10019 by Charles Acosta
[Fixed] A/C Repair was created by Charles Acosta
I just watched the A/C Leak Testing and Repair part 2 - 95 Jeep video. At the 56th minute Paul had compressed air in the system and then turned on the A/C compressor with the engine running. The readings in the manifold gauges were changing. I didn't know the A/C compressor will work with compressed air inside the system. So my question is: Did he turn on the A/C from the cabin or did he manually supply 12 volts to the clutch to check operation? Thanks.
Last edit: 9 years 4 months ago by Charles Acosta.
9 years 5 months ago #10026 by Tyler
Replied by Tyler on topic A/C Repair
Hey Charles! Moved this one to the SD Video/Book section, FYI.
I think this is the video you're talking about?
Pretty sure he just turned the A/C on in the cabin. And yep, the compressor will work with regular old air! Won't cool at all, but that doesn't stop the compressor from trying. :lol:
The following user(s) said Thank You: Charles Acosta
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
9 years 5 months ago #10035 by ScannerDanner
Replied by ScannerDanner on topic A/C Repair
Yep, just used the regular controls inside. Not only is this a nice stress test for the compressor, it is also a way to verify all of the controls work. (inputs and outputs)
Don't be a parts changer!
  • Charles Acosta
9 years 5 months ago #10044 by Charles Acosta
Replied by Charles Acosta on topic A/C Repair
Thanks guys! Originally my compressor was making noises while idling and when I charged it the clutch engaged but the noise was louder.. Found the bearing inside was shot. Changed it and now the noise is gone. Next I will try to engage the clutch with compressed air. Once that is verified the next thing to do is find the leak using again...compressed air! The money I save on freon going to waste is great!
  • Charles Acosta
9 years 5 months ago - 9 years 5 months ago #10046 by Charles Acosta
That's the video Tyler!
Last edit: 9 years 5 months ago by Charles Acosta.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 5 months ago #10068 by Dylan
Replied by Dylan on topic A/C Repair
We use nitrogen at the stealership to find leaks... B)
  • Charles Acosta
9 years 5 months ago #10074 by Charles Acosta
I used compressed air and the first thing I noticed the air was leaking from the front of compressor with the PAG oil w\dye exposed. If I'm correct I suspect the shaft seal. Its a Calsonic V6 compressor but I don't think the shaft seal is serviceable. Can't find any info online. I don't mind taking the compressor apart again.
9 years 5 months ago #10109 by Tyler
Not sure if that seal is serviceable or not. :-( I haven't replaced one of those since college, since everyone just changes the compressor. :lol:
  • Charles Acosta
9 years 4 months ago - 9 years 4 months ago #10227 by Charles Acosta
Confirmed leak!
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 4 months ago #10257 by Dylan
Anyone else who can't see the video? :unsure:
  • Charles Acosta
9 years 4 months ago #10259 by Charles Acosta
Dylan wrote: Anyone else who can't see the video? :unsure:
I can see the video but i went back to Youtube and for some reason it was private. I changed it to public setting. Maybe that was the cause.
9 years 4 months ago #10267 by Tyler
Nicely done, sir! You really did save money by testing with compressed air - any refrigerant you installed woulda gone atmospheric in minutes. :lol:
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 4 months ago #10273 by Dylan
Cool! Thx for the nice feedback. Are you going to repair the compressor?
  • Charles Acosta
9 years 4 months ago - 9 years 4 months ago #10277 by Charles Acosta
I bought the compressor from ebay and installed it. Used the vacuum pump for thirty minutes and turn it off and waited another half hour in which the vacuum was maintained close to 30 in hg. Added two ounces of oil and and about twenty eight ounces of refrigerant using Paul's techniques from his three part series.
  • Charles Acosta
9 years 4 months ago - 9 years 4 months ago #10278 by Charles Acosta
Replied by Charles Acosta on topic [Fixed] A/C Repair
Final result with the car idling! The weather was 88 degrees in Long Island, NY
