Re Video; Nissan Pickup Low Power, will not stay running (With James Danner)
- Bashar Londontech-UK
- Thank you received: 2
9 years 4 months ago #10774
by Bashar Londontech-UK
Re Video; Nissan Pickup Low Power, will not stay running (With James Danner) was created by Bashar Londontech-UK
I would like to comment on the above subject/ Video, which is a very interesting one as the symptoms is exactly identical to a low fuel supply (In that Nissan it was a faulty Mass Air Flow Sensor); My Comment is thru the following attachment:
- Dylan
- Belgium, Europe
- Thank you received: 327
9 years 4 months ago #10817
by Dylan
Replied by Dylan on topic Re Video; Nissan Pickup Low Power, will not stay running (With James Danner)
Hey Bashar! I'll post the video here. Sorry but I can't see your attachment
9 years 4 months ago #10826
Hi
I hope the file can be opened and read in its pdf format. This is an attempt to scientifically explain the unexpected cause behind the symptom in that Nissan pickup.
Bashar
Replied by Bashar Londontech-UK on topic Re Video; Nissan Pickup Low Power, will not stay running (With James Danner)
Hi
Bashar
9 years 3 months ago #10833
Replied by Noah on topic Re Video; Nissan Pickup Low Power, will not stay running (With James Danner)
Well written Bashar, thank you for taking the time to share your experience and hypothesis. I like the analogy of a cranking "masked mode" or as you also said, the PCM has it's "eyes closed during cranking".
It's something I've come to learn and accept that a good deal of inputs (and there for the scan data that correlates) are ignored during cranking, but you've articulated that much better than I could have.
The other thing to consider is that many manufacturers will go into a fail safe mode, or run in a predetermined fuel cell when a critical input like the MAF is missing. Some others do not.
I could drive my Lincoln to work with the MAF in the front seat if I wanted to.
My friends Subaru however would likely not make it to the corner store without much effort were he to try the same.
9 years 3 months ago #10855
Replied by Tyler on topic Re Video; Nissan Pickup Low Power, will not stay running (With James Danner)
Nice writeup, Bashar! This part caught my attention:
We had a member post a very similar issue recently , and I'm afraid we all got fooled into thinking about an anti-theft issue. :blush:
In the case of that thread, I think the incandescent test light actually got us in trouble. There probably WAS injector pulse width going on, but the test light was too 'slow' to pick it up. You caught onto the shortened pulse width right away by scoping the injector primary.
suspecting the engine might be immobilised, I have connected a scope to one injector to monitor
the command voltage while spaying past the MAF.
