Brake bleeding
  • Charles Acosta
  • Charles Acosta's Avatar Topic Author
9 years 2 months ago #11627 by Charles Acosta
Brake bleeding was created by Charles Acosta
I watched Paul's video when he worked on his brakes system particularly bleeding them. I plan on flushing and bleeding my brake system and buy some spare bleeding screws because from what I saw they look rusted. Let's say the process goes good but on my third or fourth the bleed screw brakes off and worse I may have to replace the caliper. Do I have to go back to the previous ones to bleed the others as well or only the bleed screw or the caliper that was replaced? Thanks.
9 years 2 months ago - 9 years 2 months ago #11629 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Brake bleeding
Modern vehicles have a split hydraulic system, usually a diagonal split system: the front left and rear right share a hydraulic circuit, while the front right and rear left share a different hydraulic circuit. In effect the two pressure circuits of the system are 100% isolated from each other. If air gets into one circuit it cannot enter the other part so you can treat them as completely seperate brake systems. If you first carefully clamp off the hose to a particular caliper or wheel cylinder to work on it you only need to bleed that caliper or wheel cylinder -- the only exception to this is the rear axle some trucks and older vehicles that have a front-rear split hydraulic system with a single shared brake line the rear axle rather than a diagonal split.
Brake fluid costs money and bleeding a brake system takes time so plan ahead. A fluid change is about reducing the ammount of water held in the brake fluid particularly in the brake calipers and wheel cylinders. Fitting new brake pads before changing the fluid greatly reduces the ammount of fluid held in the brake caliper and makes bleeding easier. When you fit new pads you can check out the condition of the brake bleed nipples before you change the fluid.
You also might want to consider tooling up most pro's are used to the tradditional way of bleeding brakes by pumping the brake pedal, but if you aren't used to the job using a pressure bleeding tool makes the job much quicker and it can be done single handed. Being UK based I use a Sealey Pressure Brake bleeder (part number VS820) but I know very similar tools are available in the USA a very quick search on the US Amazon site found pressure brake bleeders by Motive Products at a very fair price. A lot of the brake bleeders on the market use hand vacuum pump to suck the air out in theory this is better but in practice the type that work by using air pressure from the resevoir down either from a hand pump or shop compressed air are much quicker and easier to use.
The other tools that are invaluable are a Turkey Baster or large syringe to remove as much of the fluid from the master cylinder resevoir before you put fresh fluid in. ISTR like most pros Paul used long nosed vice grips with the jaws cushioned with cloth to clamp the hoses when changing the caliper -- nothing wrong with that but I would also suggest you invest 10$ or so on a pair of low cost hose pinches sometimes called hose "nipps" or clamps. A number of different types are available the ones I use are Snap-On but are almost identical to Lisle 22850 or OTC 4506. By clamping the hose before you start with just enough tension to stop fluid leaking you can prevent the hydraulic system draining down and letting air into the system ---- even when completely changing the fluid it is best to try to avoid having to start from an empty system. The other advantage of clamping the hoses is you can use it to control the fluid flow when bleeding -- and you don't have to rush to close the bleed nipple, just tighten the clamp and you can take your time to close the bleed screw.
Of course remember to remove the clamps and check the pedal is solid before driving off.
Last edit: 9 years 2 months ago by Andy.MacFadyen.
The following user(s) said Thank You: Charles Acosta
9 years 2 months ago #12461 by Tutti57
Replied by Tutti57 on topic Brake bleeding
Is there something in the hose that can be hurt if it is pinched? I feel like I remember Paul saying something about being careful with them because of a small something or other inside that can be damaged?
9 years 2 months ago #12462 by Chad
Replied by Chad on topic Brake bleeding
Tutti57 wrote: Is there something in the hose that can be hurt if it is pinched? I feel like I remember Paul saying something about being careful with them because of a small something or other inside that can be damaged?
The problem with brake hoses is that they fail/collapse from the inside and act like a check valve. You can't see this externally. When you depress the pedal, the pressure is high enough to force fluid through the collapsed section, but the pressure won't release back through. The caliper, then has constant pressure in it and the brake becomes "locked". Opening the bleeder will allow the pressure to bleed off.
This is why you NEVER let calipers hang from the hose. Stretching the hose is a sure way to make it fail. Pinching, as well, can damage it, internally.
9 years 2 months ago #12464 by Andy.MacFadyen
Clamping a brake hose with the proper tool without excessive force won't cause any problem the first company to sell brake hose clamps (at least in Europe) was major brake brake manufacturers Girling ( the same company who along with Dunlop invented the hydraulic disc brake.) among the manufacturers currently making brake hose pinches are Snap-on who are unlikely to risk there reputation on an iffy product. Clamping with vise grips is common practice BUT pad the jaws and be extra careful not to use excessive force.
Here is the original 1960's style of Girling brake hose clamp on eBay --- Laser Tools make an almost identical tool today, very gentle on the hose but the size makes it a bit awkward to use.
Letting the caliper hang on the hose isn't good --- usually I use welding wire or an old wire coat hanger or heavy duty cable ties to hang the caliper from a coil spring or other convient suspension part.
The danger from dangling the caliper on the hose is the outer layer of rubber on the hose will partly pull out of the crimped metal ferrules allowing moisture in the inner textile layer causing it to rot.
9 years 2 months ago - 9 years 2 months ago #12467 by Chad
Andy.MacFadyen wrote: Clamping a brake hose with the proper tool without excessive force won't cause any problem
I stand corrected. I was taught not to do this. However, my automotive education has been less than proper, to say the least. And, my whole career limited to a single garage. There have been MANY times I have wanted to clamp the hoses, but didn't. I lose a lot of fluid, and most times make a mess. I must say, I am re-thinking my position. :unsure:
What is the Snap On model #?
Last edit: 9 years 2 months ago by Chad.
9 years 2 months ago #12469 by Tyler
Replied by Tyler on topic Brake bleeding
pole71 wrote: I was taught not to do this. However, my automotive education has been less than proper, to say the least. And, my whole career limited to a single garage. There have been MANY times I have wanted to clamp the hoses, but didn't. I lose a lot of fluid, and most times make a mess. I must say, I am re-thinking my position. :unsure:
I was taught the same thing at school and my first shop job! Ended up at a different shop that had no issue clamping hoses, and I never caused an issue. Heck, I even clamped the rear hoses on my daily driver years ago, and they're still OK. :silly:
I was kinda curious how you guys felt about this, but was almost afraid to ask. :lol:
9 years 2 months ago - 9 years 2 months ago #12476 by Andy.MacFadyen
The Snap-on Blue Point part number is YA2850a on the left in the photo. The tool on the right is Draper equivalent --- which I don't recomend as it is too easily knocked off the hose.
There are otherways of stopping fluid loss including a pedal depressor (pedal jack) that goes between the brake pedal and the stereing wheel to hold the pedal fully depressed Snap-on B240b , Lisle 48700, Laser 3237, Sealey VSO15. The disadvantage being you can't turn the steering with the tool in use.
The other method to stem fluid loss is the Cling Film method which is simply filling the fluid resevoir up until it is on the point of overflowing and stretching cling flim across the top excluding any air . Then securing it with a rubber band or two round the neck to form an air tight seal. If the resevoir cap is a plain cap without a level switch then screwing the cap on tight over the cling also works.
This is home made gizmo for stopping fluid loss from male pipe and hose ends.
9 years 2 months ago - 9 years 2 months ago #12484 by Andy.MacFadyen
The cling film method
Rember to lower the fluid level back to normal "High" to allow for heat expansion of the fluid before putting vehicle back in service.
9 years 2 months ago #12517 by Rockyroad
Replied by Rockyroad on topic Brake bleeding
Funny,I just bought a set of those pinch off clamps from hf yesterday. Just like that little red snap on one,but 4 or 5 different sizes. Gonna pinch of coolant hoses to pull my intake.
Someday I'll figure this out
9 years 2 months ago #12590 by Noah
Replied by Noah on topic Brake bleeding
I read somewhere that pushing the pedal just off it's rest position and holding it there (with a broom stick and the driver's seat or something) will keep an open line from draining.
I haven't had to try it yet...
9 years 1 month ago - 9 years 1 month ago #12614 by Andy.MacFadyen
Noah wrote: I read somewhere that pushing the pedal just off it's rest position and holding it there (with a broom stick and the driver's seat or something) will keep an open line from draining.
Yeah that works it only takes about 2 or 3 mm movement at the master cyclinder (probably translates to about 18mm/1.5" at the pedal) to close the inlet ports off but it is probably easier to prop the pedal all the way down.
This picture kind of explains whats going on
As they say on UK kids TV "Here is one I made ealier".
Last edit: 9 years 1 month ago by Andy.MacFadyen.
Time to create page: 0.408 seconds
