hall efeect sensor identificatin?
- Sako
8 years 7 months ago #18689
by Sako
hall efeect sensor identificatin? was created by Sako
hey!
how do I identify if the hall effect sensor design is a pull up or a pull down?
- Tutti57
- Thank you received: 254
8 years 7 months ago #18820
by Tutti57
In the first example, being pull down, you could then act like the computer by putting a test light to ground and tapping on the signal wire. That should pull the voltage down, indicating good wiring. Even a rise from 0 to something else would indicate good wiring.
Replied by Tutti57 on topic Re:RE: hall efeect sensor identificatin?
You can look at the voltage on the signal wire which will be either 0v or something like 5v or 12v. Then unplug the connector from the sensor and see if there is a change in voltage. If it goes from 0v to something like 5 or 12, then it's pull down. The other way around would be pull up.Sako wrote: hey!
- Sako
8 years 7 months ago #18830
by Sako
Replied by Sako on topic Re:RE: hall efeect sensor identificatin?
thank you
I know the way to test it, but what if you have a pull down sensor where the signal is shorted to ground?
