ground or power side switch
  • nicky.van.rooyen
  • nicky.van.rooyen's Avatar Topic Author
8 years 7 months ago #18966 by nicky.van.rooyen
ground or power side switch was created by nicky.van.rooyen
starting with chapter 3 power or ground side switch decided to do test on a ford ikon in the shop purge valve koeo 12v on both wires so i think ground side switch now to find control wire unplug on first wire 12v so that is feed other wire control then it must be 0v i test and get 4v why o why it looks so easy on the videos
8 years 7 months ago #18970 by steve
Replied by steve on topic ground or power side switch
Computer control wires often have a bias voltage on them, this is what your seeing here
You have identified the feed and control wire correctly
8 years 7 months ago #18995 by Tutti57
Replied by Tutti57 on topic ground or power side switch
The easy way to tell which side is the switch is to look at a diagram and look at which wire goes to the computer. If you see one going to ground and the other going to the computer, it's power side switched. If one is coming from a B+ source and the other is going to the computer, it's ground side switched.
I'm not sure if you can determine this with confidence without a diagram or not. I'm not knowledgeable enough to try it!
  • nicky.van.rooyen
8 years 7 months ago #19096 by nicky.van.rooyen
Replied by nicky.van.rooyen on topic ground or power side switch
Thanks for your input I have problem with buying good wiring diagrams in RSA this vehicle is not made for other markets. There are a few such vehicles in RSA
