93 GM 3.1 no start case study part 1
- wnrwade
- Thank you received: 3
- ScannerDanner
- Administrator
- Thank you received: 500
Thanks!
Don't be a parts changer!
- wnrwade
Around the 1 hour mark.
Also was wondering what you considered actually shorted. I had a tech checking a circuit and he thought the computer had failed. The reason he thought this was the diagnostic procedure for the fault told him he should have no continuity to ground on the signal wire, well he had 41k ohms. This would change to open load when computer was unplugged. I told him that I would be more worried about 100 ohms or less. So we did some checking and found the procedure is just not specific. There was the same 41k on all sensor signal wires. Real issue was the sensor lost its 5v ref and threw a fault for a short to ground. Thank you again
- ScannerDanner
- Administrator
If I still had the sensors plugged in, only then would I have measured the 5v ref compared to the sensors grounds like in this series.wnrwade wrote: I just had one question, when you were checking for a short to ground on the 5v refs why did you not check them against the other pins? Especially the pins labeled grounds. Just don't know if I missed you saying you did this or if it is a wasted step I do. Thank you
I think to measure the 5v ref wire for a copper to copper short would be a waste of time. There is not one incident I can think of where a harness had a copper to copper short where is was not also shorting to ground with some major damage to the harness. I suppose in theory it could happen, it just doesn't. I also believe you would have other symptoms pointing you in this direction. Also, the customer complaint and the order of failure of this system was a factor in our approach too. I really wasn't ever worried about the harness.
- ScannerDanner
- Administrator
In that two part series I just linked you will get a better idea of what I am looking for.
So in short, I want to see more than 1000 ohms between any reference circuit and ground or sensor ground
- wnrwade
Thank you again for all you do and the knowledge you provide
ScannerDanner wrote: So in short, I want to see more than 1000 ohms between any reference circuit and ground or sensor ground
Good stuff.
Watching it now with a better grasp of the material makes much more sense.
