Chapter 3- Transistor Drivers and Output Solenoids
- Mechanic 350
- Online
- Thank you received: 15
7 years 11 months ago - 7 years 11 months ago #25052
by Mechanic 350
Chapter 3- Transistor Drivers and Output Solenoids was created by Mechanic 350
page 3-10, what does Paul mean by driver? sorry for the stupid question. Is that the same as the transistor in the pcm?
How do you check the resistance of a solenoid coil? In the topic, "Power side Switched Circuit Problems", Paul suggests to check the resistance
of the solenoid coil. And I was just wondering how's that done? Thank you.
Faulty PCM Driver? help me to understand this. thanks.
Last edit: 7 years 11 months ago by Mechanic 350.
- Mechanic 350
- Online
7 years 11 months ago #25057
by Mechanic 350
Replied by Mechanic 350 on topic Chapter 3- Transistor Drivers and Output Solenoids
Andy, can you explain the driver circuit in another form. I didn't quite get that explanation. thanks buddy.
7 years 11 months ago #25062
Replied by Andy.MacFadyen on topic Chapter 3- Transistor Drivers and Output Solenoids
The engine computer or any other smart module works on really tiny currents, but the solenoid coils in fuel injectors or relays work work on pretty large currents that would burn out normal computer circuits. The computer driver amplifies the currents and voltage up to a level that can work real physical things like relays and fuel injector using a special heavy duty transistor called a power transistor to switch the output.
A power transistor switch is really just a solid state relay , a tiny current applied to one terminal acts like switch to turn on a much higher current straight through the transistor.
Although power transistor are pretty tough they can still burn out if they get over loaded by a short or voltage spike.
The following user(s) said Thank You: Noah, Tutti57
- Mechanic 350
- Online
7 years 11 months ago #25063
by Mechanic 350
Thanks Andy for that. Much better. You the man thanks again
