Proof of good fuel pump voltage using amperage.
- blackbart
- Thank you received: 6
blackbart wrote: I’ve seen several SD fuel pump diagnostic videos where Paul states “because of the high amperage draw it proves the power and ground is good. “ I need help with this.
Someone else may be able to explain it better. But, it boils down to Ohm's Law. I=V/R, where I=Current, V=Voltage, and R=Resistance. You can't have the expected Current flow if Voltage and/or resistance is not what is expected.
Last month I was looking at a common rail diesel measured at the fuel pump fuse the curent was about 7 amps, but the fuel flow was poor and aerated and pressure took time to build.
It turned out it was a two pump system (in-tank scavenge/primer pump and under hood pump) both pumps powered through a common fuse and should be drawing about 11 amps combined total. Disconnecting the underbonnet pump and the curent dropped to zero.
At the tank multi-plug with pump still connected back probing showed the power feed was showing a heathy 12.6 volts and the ground zero volts. With pump powered up the voltage on the ground pin should be low as possible but still expect to see some voltage.
Fitted new in-tank pump (about 1/2 the size of the under hood pump) curent at the common fuse rose to the expected 10 to 11 amps. Back probing showed the power at 12.3 volts and the ground at 0.05 volts, which is okay.
Paul has a really good video on diagnosing on this on a rusty old GM dump truck
I'd like to share what I've learned because this is a concept that puzzled me in the past.
The key to the amperage confirming circuit integrity is the initial turn on spike.
The way Paul explained it to me was that you would not reach that high peak amperage at the beginning of the wave form if they was a circuit problem.
Electric motors have almost no resistance at rest, so when power and ground are first applied you get a big spike in amperage. As the motor turns and generates counterelectromotive force, the amperage is reduced to the nominal draw of the motor.
Noah wrote: Excellent responses from everyone.
The very high in-rush is one of the big disadvantages of electric motors making use of it as a diagnostic test is neat.
Inrush current link www.motiongenesis.com/MGWebSite/MGGetSta...orWithRLCircuit.html
- blackbart
blackbart wrote: I understand this if you know what amperage to expect.
Most of the fuel pumps I've tested are around 10 amps.
You can get an idea by the size of the fuse that protects the circuit. The fuse is usually double the expected current draw. So a 20 amp fuse would protect a circuit with an expected load of about 10 amps.
- blackbart
Eric O at the SMA Channel has one where the in-tank pump plumbing had an internal leak. In both cases the pump gave no electrical symptoms detectable from ouside the tank. I have had couple similar cases where the main fuel filter located inside the tank had come apart.
Another one that can throw you is if you are testing a relay and its' case flooded with water.
