MAP sensor on MAF engine
- Jonathan Haffer
- Thank you received: 13
6 years 7 months ago - 6 years 7 months ago #38159
by Jonathan Haffer
Jonathan Haffer
MAP sensor on MAF engine was created by Jonathan Haffer
23. When a MAP sensor is used on a MAF engine what is the primary purpose of the MAP ?
24. What is the mathematical formula called to measure incoming air flow on a MAP engine?
Jonathan Haffer
Last edit: 6 years 7 months ago by Jonathan Haffer.
- chief eaglebear
- Thank you received: 70
6 years 7 months ago #38190
by chief eaglebear
Replied by chief eaglebear on topic MAP sensor on MAF engine
I think on a speed density engine it's grams per second
6 years 7 months ago #38206
Replied by Noah on topic MAP sensor on MAF engine
A map sensor on a maf engine is also used to determine barometric pressure.
I believe the term you are looking for in question 24 is speed density
- Tutti57
- Thank you received: 254
6 years 7 months ago #38216
by Tutti57
Replied by Tutti57 on topic Re:MAP sensor on MAF engine
Possibly used as part of a backup strategy during MAF failure?
Nissan Technician
Nissan Technician
- Flatrater
- Thank you received: 18
6 years 1 month ago #43289
by Flatrater
Replied by Flatrater on topic MAP sensor on MAF engine
23 - Primary purpose can vary. Some common stuff would be spark timing, BARO, speed density management (backup), airflow modeling.
24 - Take a look at the ideal gas law. That is foundational, but there is a lot more. For example, Chrysler spent a lot of money enhancing their calculation which is why they were able to skip using a MAF even with VVT systems etc.
