week 5 quiz
  • Jonathan Haffer
  • Jonathan Haffer's Avatar Topic Author
6 years 7 months ago #38524 by Jonathan Haffer
week 5 quiz was created by Jonathan Haffer
1. when a MAP sensor is used on a MAF engine what is the main purpose of the MAP ?
2. On a Toyota with a non computer controlled fuel pump relay, what component is responsible for shutting off the fuel pump if the engine stalls.
Jonathan Haffer
6 years 7 months ago - 6 years 7 months ago #38531 by Noah
Replied by Noah on topic week 5 quiz
1) barometric pressure. Key on engine off MAP value represents baro, which may also be updated at wide open throttle since this condition also equates to no vacuum in the intake, otherwise known as atmospheric pressure.
2)VAF or vane air flow meter. When air is no longer entering the engine, the VAF closes and breaks the control circuit for the fuel pump relay.
That is an outdated system. I've only encountered 2. Both early '90s Mitsubishi Eclipse.
Last edit: 6 years 7 months ago by Noah.
