High O2 bias voltage
- Constable1
5 years 2 months ago #50528
by Constable1
High O2 bias voltage was created by Constable1
I was doing some testing on a 2011 Equinox following procedures in the book. Car runs fine and scan data looks good, but the bias voltage on all O2 sensors when cold or disconnected is 1.9 volts. When running the scanner is showing going up and down between .04 and .09. When I connect to my scope the reading goes between 1.04 and .9. Something I’m doing wrong?
- Constable1
5 years 2 months ago #50583
by Constable1
Replied by Constable1 on topic High O2 bias voltage
Should I be posting this in a different forum?
Ken
Ken
5 years 2 months ago #50597
Replied by Chad on topic High O2 bias voltage
Warmed up and running properly, the O2 sensor output should oscillate, at least, above 800 millivolts (0.8 volts) and below 200 millivolts (0.2 volts). Service information for this vehicle states "from approximately 40 mV to approximately 900 mV". Unplugged bias voltage on the signal wire should be 450 millivolts (0.45 volts). Scan data should reflect this. I'm not sure what, if any, bias voltage should be on the Low Ref.
The readings you listed do not sound right, at all. Where, and how, are you connecting your meter/scope?
With an incandescent test-light connected to battery negative, can you pull this voltage to zero?bias voltage on all O2 sensors when cold or disconnected is 1.9 volts.
5 years 2 months ago - 5 years 2 months ago #50598
I reserve the right to stand corrected.
After reading jreardon's reply in the repair section,Unplugged bias voltage on the signal wire should be 450 millivolts (0.45 volts). Scan data should reflect this. I'm not sure what, if any, bias voltage should be on the Low Ref.
The computer is sending out 2.9 volts on the signal wire and 1 volt on the ground wire.
Last edit: 5 years 2 months ago by Chad.
- Constable1
5 years 2 months ago #50606
by Constable1
Will retest and post.
Thanks
Thanks
Time to create page: 0.552 seconds
