EGR test light control
  • Donnyten
  • Donnyten's Avatar Topic Author
9 years 7 months ago - 9 years 7 months ago #7583 by Donnyten
EGR test light control was created by Donnyten
Following along chapter 3 output solenoids I'm attempting to energize my EGR valve in a 2000 Chevrolet Malibu. However when I put my test light to the positive control wire nothing seems to be happening though I do hear a click. On my scan tool when the car is on but not running I can see the valve position slightly respond. It may rest at 1.20,volts and when I apply my test light I can see the position signal jump to 1.50. shouldn't the signal jump to nearly five volts? Engine running when I try to energize it nothing is happening the engine is not bugging down or anything. In gear the EGR valve responds appropriately on scan tool
I'm using an incandescent test light by the way.
Am i missing something?
Last edit: 9 years 7 months ago by Donnyten.
9 years 7 months ago #7591 by Tyler
Replied by Tyler on topic EGR test light control
Hey Donnyten! The problem is that the test light won't carry enough current to fully energize the solenoid in the EGR valve. Paul measured it with an ammeter in one of his videos, came out around 1A I believe.
Anyway, that's why you're only seeing a marginal increase in EGR position when you apply the test light. Try a fused jumper (or your DVOM in the amp mode) and see how the valve responds. Verify correct polarity before jumping, of course. ;)
The following user(s) said Thank You: Donnyten
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 7 months ago #7640 by Dylan
Replied by Dylan on topic EGR test light control
Here's the video Tyler mentioned
The following user(s) said Thank You: Noah, Donnyten, Monde
9 years 7 months ago #7663 by Tyler
Thanks, Dylan! Actually, I was thinking of this one, but that's a good reference too. B)
The following user(s) said Thank You: Donnyten, Monde
  • Donnyten
9 years 7 months ago #7703 by Donnyten
Replied by Donnyten on topic EGR test light control
Thank you thank you thank you yall. Very informative
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
9 years 7 months ago #7879 by ScannerDanner
Replied by ScannerDanner on topic EGR test light control
Awesome guys! Thank you!
I'll add one more thing. The reason it did not react at all with the engine running is that manifold vacuum is now pulling on the closed side of the EGR pintle. So the already weak magnetic field you created (not enough current from your test light) cannot lift the valve off its seat with the addition of manifold vacuum.
Hope that made sense
Don't be a parts changer!
The following user(s) said Thank You: Noah, Monde
9 years 6 months ago #8964 by ceasarmobile
Replied by ceasarmobile on topic EGR test light control
can also do bidrectiona ltst egr with scanner
