This is the optional category header for the Suggestion Box.
Harness/Connector oil intrusion
- tigersfan1
- Thank you received: 2
7 years 11 months ago #24979
by tigersfan1
Harness/Connector oil intrusion was created by tigersfan1
Hey Dan, just a suggestion. on top of all your supreme video's I think it would be helpful to point out how oil intrusion into a harness or connectors can have a drastic effect on circuits and set bizarre codes. (you may have already done this) but in the heavy truck diesel field this can be quite common often the intrusion starts at the jake brake harness or injector harness and runs al the way into the ECM port and corrupts all kinds of data. thanks again Dan, I do have a pic or two but at the moment I cant find it.
- vinnyAudi
7 years 11 months ago #25035
by vinnyAudi
Replied by vinnyAudi on topic Re:Harness/Connector oil intrusion
X2
I had this happen once on a 2005 Mercedes c230. Transmission fluid whicks it's way up the harness into the cabin to the TCM. Good info to have available out there!
Sent from my SM-N920V using Tapatalk
7 years 11 months ago #25067
Replied by Noah on topic Re:Harness/Connector oil intrusion
Feel free to post up pix and examples, or even a case study if you'd like.
I'm always interested in seeing what other people are dealing with during their work routine.
