Relative compression
- naros812000
9 years 1 week ago - 9 years 1 week ago #14202
by naros812000
Relative compression was created by naros812000
Dears,
I have done a relative compression test on my toyota avalon 2012 v6 3.5 engine. Here I have uploaded the picture and I want to know your opinion of this test
Thank you
Thank you
Last edit: 9 years 1 week ago by naros812000.
- Dylan
- Belgium, Europe
- Thank you received: 327
9 years 1 week ago - 9 years 1 week ago #14208
by Dylan
Replied by Dylan on topic Relative compression
Aloha
I prefer to do a relative compression test with an amp clamp.
Moving this topic to diagnostic tools & techniques.
Last edit: 9 years 1 week ago by Dylan.
- Ro-longo
- North Salt Lake, Utah
- Thank you received: 43
9 years 1 week ago #14209
by Ro-longo
Replied by Ro-longo on topic Relative compression
Very difficult to make anything out with the picture provided. Can you try to upload a better image, thanks.
- Dylan
- Belgium, Europe
9 years 1 week ago #14210
by Dylan
Check this one out from Motor Age if you want to perform a relative compression test without an amp clamp. Also notice the AC coupling.
- karim
- Thank you received: 2
9 years 1 week ago #14212
by karim
Replied by karim on topic Relative compression
Thank you all.
I used Low Amp 20 .... relative compression test on Toyota avalon 2012 V6 3.5L. Photo updated.
9 years 1 week ago #14218
Replied by Tyler on topic Relative compression
Can you show us the same capture, but zoomed out? 500mS or 1 second on the screen would be great.
It seems like the amp probe is struggling to measure current consistently... If you were to use the same probe on a steady draw (headlight, blower motor), does it behave the same way?
9 years 1 week ago #14223
Replied by Andy.MacFadyen on topic Relative compression
With a 3.5 V6 the starter will take a huge current out of range of your clamp, as already suggest do a voltage relative compression instead .
When working single handed I do voltage relative compression test by just plugging into the cigar lighter socket. I first do an DC test to check the cranking voltage to check battery condition and charging then switch to ac for relative compression.
