HI.......I am new in this forum. Crank no start.
  • angelcoamo44
  • angelcoamo44's Avatar Topic Author
6 years 6 months ago #38962 by angelcoamo44
Hi......I am new in this forum...My name is Angel Santiago...I am from Puerto Rico. I enjoy learning about car electronics and everything related to
it...I joined the forum and eventually will subscribe to the scannerdanner youtube premium channel so i can learn more about vehicle troubleshooting. Right now i own a 1996 Mitsubishi montero that cranks but no start....has no spark, check engine light does not lid on the dashboard....there is no 5 reference volts at the sensors....and i cannot find the location of the engine power relay, so i can test it. I hope that i will find the solution within this forum and the youtube tutorials....
6 years 6 months ago #38964 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic HI.......I am new in this forum. Crank no start.
First of all welcome :-)
I will move your question into the repair questions section where it will get more response.
If I was working on your car I would do 2 simple tests to find out if your engine wsn't starting because of lack of fuel or lack of spart or lack of both fuel & spark.
6 years 6 months ago #38967 by jreardon
Behind right side of dash, above ECM
The following user(s) said Thank You: angelcoamo44
6 years 6 months ago - 6 years 6 months ago #38973 by Potanist
Did I answer this one already in a different thread, lol? Or two people have this vehicle now with problems. I'll tell you what it is right away. You have to get your ECU rebuilt. Age has effected the electronics inside it and there is no way around it. Rather you buying a used one and trying to get it to work with your vehicle only is putting you into the same situation. For your experience though trace the wires and stuff. Mine had no spark via no signal from the ecu. Try these people though because it seems they do your year... not sure who I used. www.fs1inc.com/engine-control-modules.ht...=Rebuild%20(Rebuilt)
Last edit: 6 years 6 months ago by Potanist.
6 years 6 months ago #38975 by John Curtis
Replied by John Curtis on topic HI.......I am new in this forum. Crank no start.
But to circle around real quick, to you test all the sensors for 5v? The reason I ask is because depending on the sensors you’re checking you may need to unplug before you’ll see the 5V (thermistors)
If no 5V then check powers and grounds for the ECM.
You need to verify your ECU FUSE is good. Mitsubishi tends to throw out a bunch of stuff on one power feed. So if it’s a blown fuse don’t touch anything before doing a visual inspection. Do you have a test light?
The following user(s) said Thank You: Andy.MacFadyen, angelcoamo44
6 years 6 months ago #38977 by John Curtis
Potanist wrote: Did I answer this one already in a different thread, lol? Or two people have this vehicle now with problems. I'll tell you what it is right away. You have to get your ECU rebuilt. Age has effected the electronics inside it and there is no way around it. Rather you buying a used one and trying to get it to work with your vehicle only is putting you into the same situation. For your experience though trace the wires and stuff. Mine had no spark via no signal from the ecu. Try these people though because it seems they do your year... not sure who I used. www.fs1inc.com/engine-control-modules.ht...=Rebuild%20(Rebuilt)
How do you come to the conclusion that in this case the computer needs to be rebuilt?
The following user(s) said Thank You: Andy.MacFadyen, juergen.scholl, angelcoamo44
6 years 6 months ago #38993 by juergen.scholl
Replied by juergen.scholl on topic HI.......I am new in this forum. Crank no start.
Maybe he is drawing unlimited conclusions from limited experience. ........
6 years 6 months ago #39001 by Crombie
Thinking because he said there's no check engine lit on the dash, but I remember checking a Pajero years ago 1996, and Mitsubishi used an OBD2 port, but I couldn't get anything to read it, they were still using their own diagnostics system right before all the car companies were made to use OBD2
  • angelcoamo44
6 years 6 months ago #39096 by angelcoamo44
Replied by angelcoamo44 on topic HI.......I am new in this forum. Crank no start.
Thank you very much for the information .....
6 years 6 months ago #39103 by Tutti57
Remember though, that you have to confirm power and ground at the ECM as mentioned. If you have those, then one of the sensors could be bringing the whole 5v ref down.
If you have power and ground at the ECM, start unplugging engine sensors until the 5v ref comes back up then you will have found your problem. Thermistors aren't going to be the issue due to them having a different design as outlined in Paul's book.
If you don't have good power or ground at the ECM, then you have a heck of a good direction to follow!
Nissan Technician
  • angelcoamo44
6 years 6 months ago #39108 by angelcoamo44
Replied by angelcoamo44 on topic Re:HI.......I am new in this forum. Crank no start.
Thank you very much Tutti57 for the information....
