5 v reference at 9 volts on 2003 CTS
  • Marti
  • Marti's Avatar Topic Author
4 years 8 months ago #54634 by Marti
I've joined this premium channel recently and need help with a problem causing several diagnostic trouble codes (P2138 and P2123 on the APP sensor, P0451 on the fuel tank pressure sensor, P0343 CMP sensor circuit high voltage- reads 9 v, and P0118 ECT sensor high voltage - shares the 5 v reference with the CMP sensor so it also reads 9 v). The car won't start - it cranks but sounds abnormal. I started diagnosing it on Justanswers here : www.google.com/url?sa=t&rct=j&q=&esrc=s&...qp9ckOu9QLdo6IEFR4hv
I'm thinking there is a problem with the computer ground but the wiring diagrams (attached wiring diagram or on Justanswers ) may be incomplete not showing where all the computer grounds are. Any help would be appreciated. Marty
This browser does not support PDFs. Please download the PDF to view it: Download PDF
4 years 6 months ago #55663 by MrMike
Replied by MrMike on topic 5 v reference at 9 volts on 2003 CTS
Hi Marti-
Welcome to the forum. The techs in here know their s#it. You should post your tech question in the diagnostics forum for more feedback. Good luck with your diagnostic feedback.
"The object of war is not to die for your country but to make the other bastard die for his"
