Fuel trims
2 years 8 months ago - 2 years 8 months ago #64639 by Noah
Replied by Noah on topic Fuel trims
I'm sorry but I find your data graphs very difficult to interpret. I guess I'm just spoiled by Snap-On, lol.
Just to be clear, are you chasing negative fuel trims because you happened to notice they are negative, or is there a fuel trim related trouble code or driveability symptom?
On top of total fuel trim, it is important to be aware of loop status as well.
It's not uncommon in my experience to see some unrealistic trim values when in open loop, which can occur during wide open throttle, deceleration, warm up or under various other driving conditions where power output or keeping the engine running smoothly is more important than running exactly at stoichiometric.
Last edit: 2 years 8 months ago by Noah.
  • Vincent valentine
  • Vincent valentine's Avatar Topic Author
2 years 8 months ago #64644 by Vincent valentine
Replied by Vincent valentine on topic Fuel trims
Yeah sorry for the graph, quite difficult to read.
I just happened to see they went negative as soon as i pressed the pedal. I feel no driveability issues and service manual says total fuel trims are good if +-35%
Cannot see the loop status with my scanner (you have to scan it with a special suzuki scanner to do more stuff) but i will assume that at wide open the loop opens and trims are 0. Just wondering why if i stay at 2k-3k rpm trims jump from -12 to -20.
2 years 8 months ago #64649 by bills4065
Replied by bills4065 on topic Fuel trims
great advice from Noah. Totally forgot to ask you: Did you happen to pull spark plugs out and see if any of them were wet?
  • Vincent valentine
2 years 8 months ago - 2 years 8 months ago #64650 by Vincent valentine
Yeah
They look quite well. No wetness at all.
Last edit: 2 years 8 months ago by Vincent valentine.
2 years 8 months ago #64655 by bills4065
Vincent you said you could blow through the pcv valve in both directions. If that is true, the pcv valve is stuck open.
  • Vincent valentine
2 years 8 months ago #64656 by Vincent valentine
Did blow through both but only one way worked. Its working fine.
Took injectors out yesterday. Its a four holes injector and only see two streams of liquid going out, not really atomized. Also think they are not the original ones. Maybe a chinese copy. They say "bosh license". Dont know if that mean they are original or not but rare thing they are not japanese (denso).
Trying to find the original ones in a junkyard to test them.
2 years 8 months ago #64657 by bills4065
Sorry- misread your earlier post. Thought easily blow through each way.
2 years 8 months ago #64682 by Noah
To be perfectly honest, if there's no codes or driveability issues, I would stop spending money.
  • Vincent valentine
2 years 8 months ago #64696 by Vincent valentine
Yeah i think i will leave it like it is. With all the stuff i've made is running way better than before.
Thanks for your time
Time to create page: 0.343 seconds
