[FIXED] 2001 Ford F150 P0401 code
- jayta98
So it appears that even if the PCM send the ground signal to solenoid it is not the issue as the voltage situation remains. What you do you think?
jayta98 wrote: So if I'm going to use a jumper wire to test the EVR test like showed in the video I'm going to use the jumper wire from battery ground to the brown/pink wire I should see the engine stall a little and the DPFE voltage should increase, correct? I just want to make sure I don't fry my PCM when using the jumper wire. So from battery ground to brown/pink wire? Sorry to ask twice but i want to make sure.
No problem - always good to be double sure on this kind of stuff.
Actually, in this situation, you still can't fry the PCM driver, even if you connected to the wrong EVR wire.
Thanks everyone for stepping in and help. I have this problem for about a year now. I will like to resolve it.
Thank YOU for sticking with us! We want to see this one fixed.
- jayta98
No problem - always good to be double sure on this kind of stuff.Yep, B- to the brown/pink wire should either stall the engine, or close to it.
Actually, in this situation, you still can't fry the PCM driver, even if you connected to the wrong EVR wire.The only way you could let the smoke out of the PCM would be if you connected the jumper to B+, or if you had the backprobe installed crooked enough that it was touching both pins.
One thing i have noticed is that even if I apply vacuum to the EGR directly or even when i did the EVR test the engine will idle slightly rough. I mean it is no were near stall or ever had stall. Not sure if that detail helps out.
- jayta98
Does that sounds about the right amount of air pressure? I never checked the manifold hole itself for obstruction when I removed the pipe. I can take it off again tomorrow. I can start the truck and feel the exhaust pressure coming out of it.
- jayta98
Sent from my SM-G930V using Tapatalk
I'm honestly not sure. :dry: I've never had one of those pipes off, so I can't say with confidence what kind of pressure you should feel. To me, if you can feel exhaust pulses at the main EGR valve connection and both the DPFE hose ports, then I think you're good.
- jayta98
i posted the results earlier. With the actual jumper to the solenoid the engine idles a little rough but it never stalls or dies. The voltage at dpfe is still around 1.27v. So no change there. Even if it is vacuum related i think i would have the right results when i use the vacuum pump directly on the egr valve. I get the same results and engine rough idle and no change on voltage.Tyler wrote: Hey jayta98! Didn't mean to leave you hanging... I was actually waiting to hear back about the EVR test. Did you get a result by applying a jumper wire to the EVR solenoid?
- Ben
- Thank you received: 215
- Ben
- jayta98
yes the tb is clean and clear. The egr was pulled and i manually applied vacuum. It can see internal piston moving and creating a 1/4 inch opening. The vacuum holds which tells me the diaphragm is intact. I agree it could be the tube. The only replacement is the dorman one and it seems from the reviews is not a perfect fit and needs to be modified to fit. The tube is very clear when i blow air thru it. I mean lile there is not an obstruction so i guess it could be the egr then? But it appears to be fully open.Ben wrote: Somethings isn't right here! I didnt read through all the posts so forgive me if this has already been done but If you can't stall an engine with the egr than it's either not opening all the way or either the tube or intake is plugged id start with pulling the egr apply vacuum (make sure it holds vacuum and opens fully) clean the intake port while it's off. The pipe can be more tricky but if it's neither of those than we'll look at pipe
Exactly what I've been thinking the whole time! :lol: I'm pretty sure there's a genuine low flow issue at this point, but I can't decide if it's something in the EGR pipe, or if it's the EGR valve.
Good stuff, sorry I missed that earlier! :blush: This is what makes me believe in a low flow issue, as I've done this test many times on known good vehicles, and always got them to flat-out stall.
I wanna say EGR? But I don't wanna be that guy that guesses on parts. :lol:
- jayta98
i ordered the egr valve and i will try it out. I think the current one it was a generic model so i went with motorcraft one this time. I also have a small usb endoscope camera. Im going to pull the egr tube out again and see if the tiny camera fits inside and i can look at the orifice to confirm is not obstructed.Tyler wrote:
If you are telling me that i should be able to stall the engine out with the jumper to the solenoid or by applying vacuum to the egr then it obvious there is not enough flow. I know there is no obstruction on the throttle body. i pulled the tube before and started the truck to feel for air flow at the manifold hole and i felt plenty of it. Once i get the egr valve on Wednesday is will update my findings.
- jayta98
Next I installed the new motorcraft EGR and tried the EVR solenoid jumper test. Immediately the engine idle really bad and it stalled. Now that is what you guys told me it should happen so I knew EGR flow was good this time. I installed the new DPFE sensor and put everything back. KOER i put my voltmeter on the DPFE and applied vacuum to the EGR. This time it did what it should do. The engine started to idle real bad as i applied vacuum and the DPFE sensor voltage went up from 1.02v to 3.5v and higher with the more vacuum I applied.
So after all it was the non motorcraft EGR valve. I bought the aftermarket EGR valve and installed it about 1 year ago. The valve was not the right one for the truck and it started causing the issues. I'm not buying Ford engine parts that are not OEM brand anymore. It has not been the 1st time I had issues with aftermarket parts on Fords.
I cleared the codes and so far I drove the truck 3 times and no SES light. I'm pretty sure i got it. I removed the dorman EGR tube and installed the factory one. Same voltage results and the engine stalls with the EVR test. I'm returning the tube back since it is a bad fit.
I want to thank all of you that pointed me in the right direction and took their time answer my questions. It's a long time with that SES light on my cluster.
Now I have to do some suspension work. It never ends. Juan.
Ah hah! :lol: I wonder which truck it was designed for, then? Also been down that road with aftermarket parts.
- jayta98
- Ben
Ben wrote: Good work glad you got it figured out it whenever you have 1 that won't stall an engine it's a flow problem either a plugged tube or in this case the egr valve is restricting flow
Ben is absolutely right - this is where I went wrong initially. :blush: I knew a wide open EGR should generate a stall, but I let it go because I have seen a couple that didn't stall but still passed their EGR monitor. Shoulda listened to my gut on that one.
