2006 Scion TC A/C Help
- joshuamal
- Thank you received: 3
please help
- joshuamal
- ScannerDanner
- Administrator
- Thank you received: 500
90 psi of rest psi, then a low , low side and a low, high side pressure. This is an odd symptom. It could be the compressor. What is the history of this. Why were all those other AC parts replaced? When did this problem start?
Are you 100% sure on that charge capacity? I could check too
Don't be a parts changer!
- joshuamal
Thanks for taking time to read my concern here and on youtube. These parts were change because the evaporator was leaking so the evaporator and expansion valve I replaced them, as I was trying to charge noticed the condenser had stains of leaking dye so I went ahead and replaced it. After chatting with you on youtube went home and took the charge at rest and both were the same about 90 PSI but this was at night with an approximate temp of 75 or so. After that I turned the AC on and it was close to 20 on low side and about 70 high side, neither of the pressures would cycle or rise back and forth. I tried taking a video and post it here but didn't go through.
I did check things electrically as shown on your video for the Odessy and the AC clutch was engage. I noticed the RPM changed when turning the AC on as you described on video, knowing the clutch was engage it means the compressor it's getting power, well at least in my understanding; checked the relays for power and ground. I noticed something and perhaps if you can explain this to me will greatly appreciate it so I can learn: on the relays you mentioned there must be two powers and two grounds for the control and load side, well I found this as the key must be on to check powers at relay, without the relay, the load side there was power and ground, the control side there were powers on both, had my test light on ground and show power on both but on one when it showed power on my test light the fan came on, I guess that relay also controls the fan.
can you help me on this or guide me? Maybe if you can post a copy of the diagram here so I can understand with your explanation.
For what I found out it's a low capacity system, about 16oz is what Toyota told me and Orilleys 15oz, please help me out on this capacity as well if possible, there is no label on vehicle.
By the way Paul you are a great teacher wish I was near you, I have learned quite a bit from you and trying to learn more from you, I watch at least two videos every day.
One thing if possible can you make more videos with basic tools instead of the fancy ones, I don't have scanners and scope but want to learn as much as possible. Lol .
Are you sure you have removed all shipping plugs? No restrictions?
pole71 wrote: If the clutch is engaging, chances are that everything electrical is ok. I have seen weird pressures similar to that before. A car came in from another shop. They had installed a used compressor . The little red shipping plug was STILL in the compressor!
I have been thinking about this over the last few days and that is only idea so far that i makes sense, a blockage in the high pressure side after the compressor outlet but before the high pressure test port.
It explains why the running pressures don't make sense compared the rest pressures. With the system running a lot of refrigerant must be trapped at very high pressure after the compressor but before the HP test port.
- joshuamal
Well I'm completely lost now and not sure what directions to take, the pressures I had listed were with the old compressor, today I installed the new one and now can't get the clutch to engage with AC on, I did jumped the load side of relay and it work, I have power on it all fuses good I even swap the relay and nothing, I checked the control side and I have power on both terminals so had my test light to ground and the fans came on as it's run by the control side of relay.
Not sure which way to go now
Any help will be great
- joshuamal
Not sure where to go now
As for trying to find a restriction, there will be a temperature change where there is a pressure drop. 70 psi down to 20 psi is not HUGE, but should still create a temperature change. Can you FEEL a place in the lines, other than before and after the TXV, that the temperature changes for no apparent reason?
- joshuamal
Any ideas ? Please advise I'm completely lost now
- cheryl hartkorn
- Thank you received: 130
If the command for AC Clutch is present, the GRN (2) wire at the Relay will show a ground with the relay removed. If it does, all inputs and ecm are fine. The problem lies at the relay, or after.
Back probing the BRN(2) (which becomes the GRN) wire at the ECM to ground, with the relay installed should kick on the clutch AND fans. If it does, you have an input or .ECM problem
- joshuamal
Any other ideas?
You have to start charging to increase the internal pressure before the clutch will kick in. :whistle:joshuamal wrote: I have no freon on it yet as the clutch would not engage
Low pressure cut out.
- joshuamal
joshuamal wrote: If I can't get it to engage, how is it going to suck the freon .
It doesn't "suck" the freon in. The pressure inside the can is higher than atmospheric pressure. When you open up the pressure of the can to the (should be vacuumed down) lower pressure of the system, the pressure FORCES the freon into the system. The pressure inside the system will start to rise. The pressure will continue to rise until it equals the pressure inside the can, or freon runs out. If the pressure inside the system becomes equal the pressure in the can (70 psi? I'm not sure of the can pressure), no freon exchange takes place. This, or slightly before this, is where you would know you have and engagement problem. The pressure sensor will detect this pressure and say "OK, I have some freon. Start the compressor". When the compressor kicks on, the low side pressure is THEN pulled down to about 20 - 40 psi. while the high side continues to build more pressure.
- cheryl hartkorn
