2006 Scion TC A/C Help
- joshuamal
- Thank you received: 3
9 years 1 month ago #13299
by joshuamal
Replied by joshuamal on topic 2006 Scion TC A/C Help
Without any freon in the system, would the clutch engage when you turn AC on or not? Because before the compressor changed when I replaced the evaporator I remember seeing it engaged, at this point I'm trying to see all possible options and I appreciate all your information and inputs. I noticed now there was no rpm change as Paul Danner showed on his video and previously I noticed that change but I will try again your advice, I'm going vacuum system again and try charging, is it possible or safe to jump the load side of relay to turn clutch on while being charged manually? With the scan tool is it safe to command on while charging? I'm getting a scan tool on Tuesday.
Please advise and thanks for all again , there are things I'm still learning
- cheryl hartkorn
- Thank you received: 130
9 years 1 month ago #13302
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2006 Scion TC A/C Help
when you pull it under a vacuum and charge it up you should have a working system.
- joshuamal
9 years 1 month ago #13313
by joshuamal
Yes I am trying to charge it up manually as I don't have a machine and the clutch doesn't engage when o turn it on
It will kick on if I jump it at relay
- Away
9 years 1 month ago #13318
No.
It will kick on AFTER you begin to charge.
Replied by Chad on topic 2006 Scion TC A/C Help
joshuamal wrote: Without any freon in the system, would the clutch engage when you turn AC on or not?
No.
