P0171 code, but negative LTFT (and STFT)
  • lc1927
  • lc1927's Avatar Topic Author
8 years 11 months ago #15487 by lc1927
Replied by lc1927 on topic Re:P0171 code, but negative LTFT (and STFT)
Hi Ben,
I will check this out. Basically I replaced the pads, had a low spongy pedal. Bled and checked that discs were free and spun and checked they were engaging by pressing the pedal. All seemed fine. I will look over it all again today, thanks.
8 years 11 months ago #15488 by Ben
Did you have this problem before pad replacement? What type of caliper does this have standard 2 pin slider single piston?
  • lc1927
8 years 11 months ago #15489 by lc1927
Ben wrote: Did you have this problem before pad replacement? What type of caliper does this have standard 2 pin slider single piston?
I actually don’t know what it felt like originally, when I purchased the car, I replaced put the pads as the first thing. The previous mechanic had (I know it wasn’t the owner, he knew nothing about cars) disconnected the low pad sensor wires to stop the warning light- the pads were so low that one of the sensors was ground down to a spec and virtually about to be disc and backing plate as the only braking to rely on.
They had also filled up the brake fluid right to the cap on the master cylinder, to compensate for the amount of fluid needed to push the (non-existent) pads out to the disc.
Yeah, just the usual 2 slider pins (checked them, none were out of grease and no signs of unusual wear). I had a VW that had worn sliders that caused noise, hence I thought I would check these ones whilst I was there. Single piston rear and twin fronts.
