Auto shutdown issue
- Mort
8 years 7 months ago #17226
by Mort
Replied by Mort on topic Auto shutdown issue
like I said I checked the wiring between 85 at the relay and 67 at C2 the wire is good no open so I would assume it would be a driver issue I don't have a fuel pressure tester and haven't checked pulse yet
- Mort
8 years 7 months ago #17278
by Mort
Ok I put my meter on B+ and touched Neg - side to 85. yes I have voltage there. while cranking it drops to 9.67 but not to zero as you suggest. I understand how the relay works I taught basic electrical for 15 yrs, but I don't understand why it doesn't energize. I put a probe in the back of position 67 of C2 which goes to the 85 side 0f the relay with the KOEO I grounded my light and touched the probe this immediately energized the relay seems to me that the PCM isn't completing the circuit. Also picked up a set of Noid lights , no I am not getting any ignition pulse nor spark. when I turn the ignition to the on position i get 12V for about 2 seconds then zero From the video I understand this to be normal but basicly no voltage when cranking. could this be a cam or crank sensor issue? if so how do i test the sensors?. really don't understand why I have voltage on all three wires going into the MAP sensor I have checked the wires none of them are crossed. I did break down and buy a fuel pressure tester I jumped the pump relay and have 60psi so the pump does work
- Dan17059
8 years 7 months ago - 8 years 7 months ago #17397
by Dan17059
Replied by Dan17059 on topic Auto shutdown issue
This is just a shot in the dark..but isn't this one of the years where the harness melted together down behind the coil? I had one that had melted together and even after fixing all the wires it still wouldn't start. I can't remember exactly what Was fried but those wires touching fried something in the pcm. Pretty sure it had to do with the 5v ref....been too long ago
Last edit: 8 years 7 months ago by Dan17059.
- Mort
8 years 7 months ago #17408
by Mort
Dan I haven't found any melted wires in this van. This problem all started according to the owner, when the Dr side tire blew out and shredded the wiring in the wheel well. I repaired all of the wiring, but it still won't start. I'll recheck the wires going to the coil. I personally think the PCM got fried when the tire blew. When I got the vehicle from the owner a lot of the bare wires were taped together. I really need to figure this thing out. I've had it since New Years the owner hasn't said anything but i'm sure he would like to get it back.
- Mort
8 years 5 months ago #19400
by Mort
Finally got this Van repaired. After checking every wire in the engine compartment I determined the PCM was indeed fried. It took almost a month to get the computer from my source. Next time I'll go with my gut instinct. I had too much voltage in places that it shouldn't have been for it to be anything else but the PCM. thanks for all the input folks
- Mort
8 years 5 months ago #19415
by Mort
Glad to hear that the van has been repaired
Thanks Mondo. my biggest hindrance was the weather almost 3 months under 20 degrees with no heat in the shop. Again thanks Everyone
Time to create page: 0.241 seconds
