2004 Seville stall, no crank.
  • David56
  • David56's Avatar Topic Author
8 years 7 months ago #18722 by David56
David56 wrote:
David56 wrote:
pole71 wrote:
David56 wrote: The poping noise stopped everything. Nothing works not even dash
Noise sounded like it came from trunk. Thanks
Do you have power on any of the fuses in the fuse block under the rear seat?
Yes that's the only place. Box in front nothing in middle works.
Sent from my LGL52VL using Tapatalk
Yes power in backseat box. Just pulled ecm never seen a green and white wire.
Update that is abs box behind glovebox. Ecm was in where the air filter goes. Half air the other side compartment is ecm. Thanks
  • David56
8 years 7 months ago #18723 by David56
pole71 wrote:
cheryl hartkorn wrote: looks like you might have a bad ignition 1 relay in the front fuse box. what turns that relay on??
Key in START or RUN
Thanks I blew this up but can't make it out.
  • David56
8 years 7 months ago #18724 by David56
David56 wrote:
Key in START or RUN
Ok now today while hunting for the car computer I heard noises from the fusebox out under the hood. Plus I noticed something wrong at the bottom drivers side hanging down and broken. No idea what this is. Must be old age. Here are the pics. Thanks
Now this thing has 2 hoses that hook up to it. Sits in a bracket. Pain to remove. Thanks
  • David56
8 years 7 months ago #18727 by David56
David56 wrote:
Key in START or RUN
Replaced relay with a new one. Nothing hey just saying.
  • David56
8 years 7 months ago #18732 by David56
David56 wrote:
David56 wrote:
Key in START or RUN
Ok this thing in picture is a smog pump. I noticed that its open at the bottom? Looks like some kinda cover would go on it. Ebay sells these just as you see it. Took all kinds of broken plastic from around it. So badly broken couldn't tell what it was. Thanks
