2013 Yukon Denali XL 1500 6.2 overcharging
- Echo1
1 year 6 months ago #89928
by Echo1
Replied by Echo1 on topic 2013 Yukon Denali XL 1500 6.2 overcharging
Working in Gm shop have seen numerous batteries that were new to the customer, I’ve even seen brand new acdelco batteries that were new and had problems. I Always start a diag with load test to eliminate bad battery.
- jd64
1 year 6 months ago #89943
by jd64
Replied by jd64 on topic 2013 Yukon Denali XL 1500 6.2 overcharging
Instrument Cluster Description and Operation portion of AllData found this interesting.
Battery Gauge
The IPC displays the voltage as determined by the regulated voltage control (RVC). The IPC receives a serial data message from the body control module (BCM) indicating the battery voltage. When the engine is ON, the gauge should be between 10–16 volts. The gauge will default to 0 volts if the IPC detects a loss of communication with the BCM.
Battery Gauge
- jd64
1 year 6 months ago - 1 year 6 months ago #89970
by jd64
Can you confirm the Battery Current Sensor is creating the PWM and the BCM is providing the 5v to the sensor?
Recommendations on load testing? I ony have the AL539b that I know is capable of testing the battery and it passed. I haven't done the traditinal load test with the cables analog meter and a spring inside that heats up.Working in Gm shop have seen numerous batteries that were new to the customer, I’ve even seen brand new acdelco batteries that were new and had problems. I Always start a diag with load test to eliminate bad battery.
Last edit: 1 year 6 months ago by jd64.
- jd64
1 year 4 months ago #91881
by jd64
Afternoon all! I think I have found the issue. Looks like one of 3 the grounds that go to the block was broken off in the wire rap/tape.
Have repaired it and the vehicle ran for a good 30 min never charging over 15v.
Will be driving it to church tomorrow so that will be a good test to see.
- jd64
1 year 4 months ago - 1 year 4 months ago #91913
by jd64
Good morning, 20250621!
I have driven the Yukon to church and a couple days to work.
I am happy to report the following!
The voltmeter in the dash now reflects the homemade voltermeter.
The vehicle has not reached or exceeded 15v.
Full air and driving lights after the initial start up sits around 14.3-14.5v.
To clarify the repair!
The stud that fastens the Batt - cable to the block has an additional eye for a circuit ground. When replacing the ground cable/batt - I noticed it looked like the cable fastener should have had 2 wires crimped and it did not. After looking and peeling back the wire tape the other ground was found.
I made a ring/eyelet added it back to the stud and things are now working as they should.
Hope this helps someone!
I am glad I took all the comments, research, manuals, forums with a grain of salt and stayed on this!
My instinct said it wasn't right, however all the manuals said it was within specs.
God has blessed me with the ability to figure things out and very greatful for this !
Last edit: 1 year 4 months ago by jd64.
1 year 4 months ago - 1 year 4 months ago #91917
Replied by Noah on topic 2013 Yukon Denali XL 1500 6.2 overcharging
That's great news! I'm glad you dogged it out and got to the bottom on it. I'm sure it will help someone in the future
Last edit: 1 year 4 months ago by Noah.
Time to create page: 0.360 seconds
