2015 ford transit no crank/no start UPDATE
- surplus238
- Hardtopdr2
- Thank you received: 150
- surplus238
- surplus238
Does not have power to pin 47
Does not have power to pin 25
If you have Power at the RED arrow, but not the BLUE arrow (with the key in the START position), then you have a faulty ignition switch.
- surplus238
- Hardtopdr2
- surplus238
- surplus238
The switch is working properly.
I will check pin 16 in the morning, This should be checked with the connector off of the PCM, right?
surplus238 wrote: This should be checked with the connector off of the PCM, right?
For this test, it doesn't really matter. Personally, I would leave the connector connected, and back-probe the Pin.
- surplus238
- surplus238
If you don't get power on Pin 37, double check the PCM Powers and Grounds.
- surplus238
surplus238 wrote: I need to drive a connection (pin) into the white wire with the green stripe and test for power in start position?
Yes.
- surplus238
While I was in there I checked continuity between my test connector and #29 fuse it is a good connection so the wire is good. If I were to jump that wire would the starter turn?
In addition to jumping POWER to this circuit, you will also need to supply a GROUND on the yellow wire from Pin 7 to activate the RELAY. Alternatively, you you could pull the RELAY and supply a power, only, to the GRY/ORG wire going to the Stater Solenoid, from the relay. This should crank the starter, too.
