Re:Re:Re:Re:Re:Re:Help Help P0032 FIXED!!!!!
  • Mariowinax1
  • Mariowinax1's Avatar Topic Author
5 years 8 months ago #46965 by Mariowinax1
Replied by Mariowinax1 on topic Re:Help Help P0032
Tutti57 wrote: Have you done a visual inspection of the wires to make sure there isn't a short to ground on the power side somewhere that's causing that fuse to blow? Push and pull on the harness and all of that?
My bad, after working on the 02 sensor wiring (Checking short to power/ ground) i didnt duct tape the wires so i bet it was coming together as i drive. So thats the genesis of it, taped it now and am good.
Is it that warm there in the morning? I would expect the temps to be closer to each other, and near ambient.
Yes, am in Africa and i climate is mostly hot.
Did you have a p0128 before? If your thermostat isn't sticking open or your ECT sensor wonky, there may be a bulletin that addresses that code with an ECM update. I'm not 100% sure if it applies to that year though.
Yes, i often have that code but its goes itself.
I think my ECT is defective!
Do those temperatures change when it warms up to believable numbers?
Yes
Not sure if it could be tied to what scannerjohn was saying about the diode.
  • Mariowinax1
5 years 8 months ago #46966 by Mariowinax1
scannerjohn wrote: Couple of things to start with that seem wrong. First you should not be blowing fuses on the O2 circuit. Somewhere along that wire it is touching to ground.
Second the engine temp is high. Is the temp where your at 100 degrees? Same goes for the intake air temp. Unless it HOT outside these temps should reflect ambient temps.
I know you asked more questions but these three must be fixed first.
Keep me posted.
Blowing fuse solved as i explained above
Oh k, i am in Africa and i our climate is mostly hot
Update
I have an old worn out ECT sensor lying around so i throw that part to replace my current one.
PCM/ECM started to enter Close loop smoothly without problems.
I think its a fix with having a good replacement to my ECT sensor.
But am still having higher fuel trims, feedback from the 02 sensor when monitoring
Wideband 5.11 volts constantly translation in stft 25% whiles ltft 9%
Is it the ECT sensor still?
Guys, God bless you for helping me with this.
SO much appreciated
Avoidance of doubt, the ECT fixed the close loop problem.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
5 years 8 months ago #46974 by VegasJAK
Replied by VegasJAK on topic Re:Help Help P0032
Great. Now that's working. High fuel trims at idle indicates a vacuum leak if the trims get better when you increase rpm. Increase rpm to 2500 and hold and see what trims do.
  • Mariowinax1
5 years 8 months ago #47002 by Mariowinax1
scannerjohn wrote: Great. Now that's working. High fuel trims at idle indicates a vacuum leak if the trims get better when you increase rpm. Increase rpm to 2500 and hold and see what trims do.
Am afraid it not totally fixed, close loop is working now btw.
I am still having P0032 trouble code.
Am confident the problem i have now is the signal wiring not grounding the 02 sensor, when i back probe it when engine is running; its still showing 13~14+ volts (Alternator running), engine off is 12 volts. It only drop to zero volt when 02 sensor is unplugged on KOEO.
Am confident is not short to power / ground because is will have still shown 12+volts even after unplugging 02 sensor.
Your thoughts?
Can i send a ground ONLY to the signal wire and monitor what happens observing it in obd scanner without problems?
5 years 8 months ago #47003 by Tutti57
Replied by Tutti57 on topic Re:Re:Help Help P0032
Yes, this is what Chad was saying before. Koeo, use your test light to ground the signal wire and watch scan data.
5 years 8 months ago #47009 by Chad
Replied by Chad on topic Re:Re:Help Help P0032
To be clear, I was referring to the heater control wire, and a bias voltage.
5 years 8 months ago #47021 by Tutti57
Replied by Tutti57 on topic Re:Re:Re:Help Help P0032
Oops, sorry, I forgot where we were at here. Did you ever do the test Chad mentioned though?
Do you have 12v on both heater wires with it plugged in?
  • Mariowinax1
5 years 8 months ago #47032 by Mariowinax1
Matt T wrote:
Chad wrote: When the ECM energizes the Heater circuit, it applies a GROUND to the Heater control wire.
You know it's gettin' serious when we break out the crayons :silly:
According to SI it ain't that simple. Looks to be PWM control so you'll never measure 0V on the control wire. Also sounds like there is a shunt inside the ECM with voltage sensing upstream of it. That sensed voltage being too high is what pops the P0032. If the control wire isn't shorted to power ECM grounds would be the next thing to go after. After that are the replacement AFRs OEM or aftermarket?
I want to start exploring the ECM grounds for a possible fix, can you direct me ?
  • Mariowinax1
5 years 8 months ago #47033 by Mariowinax1
Replied by Mariowinax1 on topic Re:Re:Re:Help Help P0032
Tutti57 wrote: Oops, sorry, I forgot where we were at here. Did you ever do the test Chad mentioned though?
On sensor plug in
I have 12v on Heater power and Signal control wire
5 years 8 months ago #47035 by Chad
Replied by Chad on topic Re:Re:Re:Help Help P0032
Mariowinax1 wrote:
On sensor plug in
Just to clear up some terminology, when referring to "Control" and "Signal", they are not the same thing. Think of these two terms from the PCM/ECM point of view. A "Control" is a PCM/ECM OUTput. The PCM sends OUT a command (to turn on the heater). A "Signal" is a PCM/ECM INput. The PCM receives an INput from a sensor (air/fuel ratio, in terms of voltage). I believe, you are referring to the heater CONTROL, not the sensor SIGNAL. Sorry to nit-pick. Just trying to avoid confusion.
The following user(s) said Thank You: Noah, Tutti57
  • VegasJAK
  • VegasJAK's Avatar
5 years 8 months ago #47044 by VegasJAK
Replied by VegasJAK on topic Re:Re:Re:Help Help P0032
The problem is in your heater control circuit. If you're 100 percent sure the 02 you're using is the correct one and you tested it then the problem lies within the circuit. You should have 12v on the control wire KOEO. As this is a pulse width modulated signal to pull down the voltage you will need a scope to check the signal. Using a volt meter will not work as it will show you the average voltage reading not the pulse and amps like you need to see. That circuit will have 12v at start up for about 10 seconds then start modulating. Their should not be more than 10amps. That's why your getting the P0032. At worse it's the ecm. Something is not grounding. Look at all other sensors and grounds that share that ground. Also check the relay that powers that R/B wire. A bad relay can be the problem. Sorry, I do not have more to offer. Good luck to you.
5 years 8 months ago #47046 by Dtnel
Replied by Dtnel on topic Re:Re:Re:Help Help P0032
With all the issues you're having make sure you have a OEM O2 sensor as it's known out there with some brands that O2 sensors are a thing you want to stick close to OEM on. Learned alot about this in a update webinar with G truglia last fall.
Are you a TST member by chance? For $174 yr total , $75 TST membership fee & $99 for unlimited video access to video library @ TST website.
TST stands for Technician Service Training. People can work in the industry but if you're not doing annual training yearly throughout the year you're going to get left behind as vehicles, ways of doing things, etc change so keeping up to date is good.
Members also get discounted Live Webinars generally with PDF booklets to make notes or have to follow up with.
IF you go to the TST "Big Event"(Virtual This Year) you also get a discount being a member.
I also subscribe to Scannerdanner. There's so much to be learned with today's Advanced videos.
HE needs to watch some videos with pull down circuits and some with ground side switched circuits as well.
I watch and rewatch them and still at times, well um read to much into things. I'm more of a hands on person so at times I procrastinate more than I should because of this.
Love doing it though and wouldn't have it any other way.
Back to the O2 sensor I only replace with OEM or if they don't want it I charge them their diagnostic fee, put the crappy one in that they want cheap and tell them there's no warranty if it comes back for same condition if I swap the O2 circuit!
Like the good explanations, diagrams & added on drawings in here on this one.
That type of stuff is what helps me get into the right mind frame to understand things better if I haven't seen them in awhile.
  • Mariowinax1
5 years 8 months ago #47051 by Mariowinax1
Chad wrote:
Mariowinax1 wrote:
On sensor plug in
Yes, heater control wire i mean
  • Mariowinax1
5 years 8 months ago #47052 by Mariowinax1
scannerjohn wrote: The problem is in your heater control circuit. If you're 100 percent sure the 02 you're using is the correct one and you tested it then the problem lies within the circuit. You should have 12v on the control wire KOEO. As this is a pulse width modulated signal to pull down the voltage you will need a scope to check the signal. Using a volt meter will not work as it will show you the average voltage reading not the pulse and amps like you need to see. That circuit will have 12v at start up for about 10 seconds then start modulating. Their should not be more than 10amps. That's why your getting the P0032. At worse it's the ecm. Something is not grounding. Look at all other sensors and grounds that share that ground. Also check the relay that powers that R/B wire. A bad relay can be the problem. Sorry, I do not have more to offer. Good luck to you.
Thanks John
Will explore your inputs
  • Mariowinax1
5 years 8 months ago #47053 by Mariowinax1
Dtnel wrote: With all the issues you're having make sure you have a OEM O2 sensor as it's known out there with some brands that O2 sensors are a thing you want to stick close to OEM on. Learned alot about this in a update webinar with G truglia last fall.
That type of stuff is what helps me get into the right mind frame to understand things better if I haven't seen them in awhile.[/quote
Am convinced is not the 02 sensor, because when the sensor is unplugged, code cleared and car restarted.
Its still throws P0032 as the sensor is even unplugged!
  • Mariowinax1
5 years 7 months ago #47321 by Mariowinax1
#Update
Purchased new o2 sensor replaced it with the old one, still trouble code is still present!
Changed ECM to a different one, the new one is showing P0031 instead of P0032
Replaced my old ECM code returns to P0032.
Whew...
5 years 7 months ago #47327 by Tutti57
Replied by Tutti57 on topic Re:Re:Re:Re:Help Help P0032
What's the part number on the sensor you just put in?
Did you verify wire integrity from the sensor to the ecm besides visual inspection on the ground side?
The following user(s) said Thank You: Mariowinax1
  • Mariowinax1
5 years 7 months ago #47328 by Mariowinax1
Replied by Mariowinax1 on topic Re:Re:Re:Re:Help Help P0032
Tutti57 wrote: What's the part number on the sensor you just put in?
Part number is 211200-7070
Sure, done that.
Remove the dedicated ground wire for the sensor, cleaned it and retighten it .
5 years 7 months ago #47334 by Tutti57
Replied by Tutti57 on topic Re:Re:Re:Re:Re:Help Help P0032
Is that an o2 or a/f sensor? I don't have the diagram up right now, but doesn't the heater ground go from the sensor to the ecm?
  • Mariowinax1
5 years 6 months ago #48478 by Mariowinax1
Replied by Mariowinax1 on topic Re:Re:Re:Re:Re:Help Help P0032
Its AFR sensor
Apart from power 12v from the IPDM to the sensor all other three is connected from and to ECM to 02 sensor
Sent from my VS995 using Tapatalk
Time to create page: 0.504 seconds
