Problem child
  • welj31
  • welj31's Avatar Topic Author
5 years 7 months ago #47731 by welj31
Replied by welj31 on topic Problem child
i am going to re run the compression test wet/dry and leak down test all while its still warmed up. this will take me a while. Will post results asap thank for the help
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
5 years 7 months ago #47732 by VegasJAK
Replied by VegasJAK on topic Problem child
Have to have ignition disabled and all plugs installed. Hold accelerator to floor instead of disabling fuel pump. If already disabled fuel pump ok. Some subscribe to holding WOT when doing compression test but fuel pump has to be off no matter disabled at relay or holding accelerator to floor it stops flow of fuel.
5 years 7 months ago #47736 by Tyler
Replied by Tyler on topic Problem child
welj31 wrote: i swapped plug 8 with plug 2. no scanner says misfire is in cylinder 1/6 WTH? will try the flood crank now.......cranks normal no odd ups or downs
BTW it starts on the 3 rotation
The misfire monitor may be struggling because #1 and #8 are adjacent in the firing order. 1-8-7-2-6-5-4-3
But that doesn't really matter - the miss counts moved when you moved the plugs. If you're still proceeding with the compression test, I say swap all the plugs between banks. In other words, take all the bank one plugs and move them to bank two. Recheck your miss counts.
  • welj31
5 years 7 months ago #47745 by welj31
scannerjohn wrote: Have to have ignition disabled and all plugs installed. Hold accelerator to floor instead of disabling fuel pump. If already disabled fuel pump ok. Some subscribe to holding WOT when doing compression test but fuel pump has to be off no matter disabled at relay or holding accelerator to floor it stops flow of fuel.
"all plugs installed"??
  • welj31
5 years 7 months ago #47746 by welj31
compression test results:
1# 178 DRY / 210 WET
2# 178 DRY / 188 WET
3# 178 DRY / 210 WET
4# 178 DRY / 190 WET
5# 180 DRY / 188 WET
6# 178 DRY / 192 WET
7# 180 DRY / 200 WET
8# 178 DRY / 190 WET
I did not notice any leak down on my compression gage, but i will do a leak down test in morning.
  • VegasJAK
  • VegasJAK's Avatar
5 years 7 months ago #47794 by VegasJAK
Yes, all plugs installed. You're checking for uniform compression.
The numbers look Ok. Do you still have fluid on the #8 plug after swapping plugs as suggested?
If oil, can be bad valve seal or intake gasket leak. Fuel could be leaking injector. I'd expect your fuel trims to be off on bank 2.
Did you get it fixed?
I have an 04 Tahoe Z71. It goes through a qt of oil about ever 3k miles. The #2 knock sensor is bad, 108 ohms so it goes off intermittently. Other than that it is a great SUV.
  • welj31
5 years 7 months ago #47873 by welj31
Sorry guys our internet went down during last storm. We will be back at it today. I agree I am thinking intake or valve seal. Leaning towards the seal as I am thinking it's oil on plug along with the smoking (very light blue / white). Do not seem to be loosing any coolant.
  • welj31
5 years 6 months ago #48068 by welj31
Well long story short we installed new valve guide seals (it was oil on plugs). Smoking stopped, misfire stopped and running ok for now. Cant scan at this point to reset code as laptop screen went bad LMAO Thanks to everyone for your help.
