[FIXED] 2001 ACURA CL 3.2 CRANKS/ NO START
7 years 3 months ago #31647 by Noah
Replied by Noah on topic 2001 ACURA CL 3.2 CRANKS/ NO START
guafa wrote:
In fact, you mentioned you started this engine with brake cleaner, which makes me think there is not a mechanical issue.
Exactly. It just about has to be fuel. Either contamination/quality or an input issue resulting in so much it drowns the plugs.
The following user(s) said Thank You: tim.smith1
  • tim.smith1
  • tim.smith1's Avatar Topic Author
7 years 3 months ago #31648 by tim.smith1
Replied by tim.smith1 on topic 2001 ACURA CL 3.2 CRANKS/ NO START
@Noah reasons i am not looking back into fuel and just an fyi i have a r/c bottle with a fuel sample in it from this car at my shop is when we changed the fuel pump like idiots lol we noticed there was very little gas in the car so of course when the car would not start we put 5 gallons of gas that i ran up to circle k a big chain gas station and put it in the car. then someone questioned the gas so for that reason i did take a sample and i look at it everyday it has no separation i sure wish it would but it is not cooperating with me lol
7 years 3 months ago #31650 by Noah
Is this a type S, with a normally open electronic throttle body mounted in front of the mechanical throttle body?
Maybe not relevant but I am curious.
  • tim.smith1
7 years 3 months ago #31652 by tim.smith1
Noah wrote: Is this a type S, with a normally open electronic throttle body mounted in front of the mechanical throttle body?
yes s type sorry maybe i should have said that before now
7 years 3 months ago #31653 by guafa
Replied by guafa on topic 2001 ACURA CL 3.2 CRANKS/ NO START
Guys, do we know anything about injectors?
How about a balance test? but all injectors at the same time?
cheers.
7 years 3 months ago #31659 by jreardon
Replied by jreardon on topic 2001 ACURA CL 3.2 CRANKS/ NO START
Take a fuel sample from the fuel rail and see if it will burn.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
7 years 3 months ago #31661 by ScannerDanner
Replied by ScannerDanner on topic 2001 ACURA CL 3.2 CRANKS/ NO START
Replying at page 3 to when the injectors should fire.
I've seen them fire during the exhaust stroke on many, many cars. In my opinion, it gives the fuel more time to vaporize. Intake valve is closed during that time, so the fuel sits there for a few extra milliseconds.
Injectors do not have to fire on the intake stroke and certainly shouldn't be firing on the compression stroke on a non gdi system.
I haven't finished reading the posts yet...
Don't be a parts changer!
The following user(s) said Thank You: jreardon, tim.smith1
  • tim.smith1
7 years 3 months ago #31662 by tim.smith1
Fuel
  • tim.smith1
7 years 3 months ago #31664 by tim.smith1
Just so you guys see what the plugs I took out look like
The following user(s) said Thank You: jreardon, aboudi.naddaf
7 years 3 months ago - 7 years 3 months ago #31665 by jreardon
@ScannerDanner Are these ignition control signals to base of transistor supposed to look like that? I thought they'd be more squarish.
@tim.smith1 On the bottom pic where it's more square, you had the connector off cop correct?
It does look a little funny but I wouldn't be concerned with that as long as the coils are firing and they clearly are. The second picture, is that the same signal with the coil unplugged? That looks more like what we would expect but I definitely have seen the base circuit trigger signal be distorted by the current flow of the coil. So again, I don't think this is your problem. I think someone commented on inputs and timing and I would like to see this too. Maybe a relative compression test synced with the base circuit trigger signal on one of the coils to start with.
Last edit: 7 years 3 months ago by ScannerDanner.
  • tim.smith1
7 years 3 months ago #31666 by tim.smith1
Okay so cleaned off plugs again and dried out cylinders as you see in data pid where the blue trace is car started on its own for a second you will see that rpm is at 1280
  • tim.smith1
7 years 3 months ago - 7 years 3 months ago #31667 by tim.smith1
cant seem to load anything lol
Last edit: 7 years 3 months ago by tim.smith1.
  • tim.smith1
7 years 3 months ago #31668 by tim.smith1
how do i load a movie from a versus to the forum page. the two picks are green off the number four coil control wire and yello with amp probe set at 1mv/10ma and scope was set 50 mv seems that is way to low on amps for injectors. ohhh and it was off of fuse for the main relay that controls injectors.
  • tim.smith1
7 years 3 months ago #31669 by tim.smith1
showing the fuse
7 years 3 months ago #31670 by jreardon
tim.smith1 wrote: how do i load a movie from a versus to the forum page
www.mediafire.com
www.zippyshare.com
I've think it's time we have a look at your cam and crank signals. When you have outputs that are not being turned on, like fuel injectors, it's probably due to bad inputs. Just look at the missing ramps !
7 years 3 months ago - 7 years 3 months ago #31672 by jreardon
On second viewing I think those are the two initial igt signals. Maybe the 2.2 amps is all the injectors firing simultaneously. Maybe the missing ramps are normal? Are you missing any more ramps thereafter in a longer time frame?
If not, then that would mean there's a power or ground issue because ~250mA of current is too low for an injector. Or maybe your homemade fuse jumper has too much voltage drop, maybe the amp clamp is low on batteries, maybe you didn't zero out the probe... too many variables lol.
I could go either way on checking out the cam and crank signals or voltage drop testing a fuel injector feed. Seeing that peak amperage ramp at 2.2, yeah, just pick out a single power feed at the nearest injector, crank engine, and do voltage drop test on it.
EDIT: You know what would be easier to check power and ground to injector? Put on your attenuator and capture an injector voltage waveform.
Last edit: 7 years 3 months ago by jreardon. Reason: spelling
7 years 3 months ago - 7 years 3 months ago #31676 by jreardon
Dunno if this is pertinent:
Code:
https://youtu.be/pUpUp0cea00?t=1566
7 years 3 months ago #31681 by guafa
Jreardon: Completely pertinent. 250mA is to low for me also (unlees tools were not fast enough to graph peaks)
Tim.smith: According to pictures of spark plugs, i was expecting totally wet ones.
I mean, wet without resistors and dry with resistors (if it's the case, we can conclude something).
did you notice any diference with and without resistors?
I can't still conclude wheter is lack or to much fuel
  • tim.smith1
7 years 3 months ago #31682 by tim.smith1
  • tim.smith1
7 years 3 months ago #31683 by tim.smith1
was testing that tell me if it works guys
Time to create page: 0.518 seconds
