[FIXED] Bad TIPM or Starter relay port on PT 09
  • c0astl|ght
  • c0astl|ght's Avatar Topic Author
9 years 8 months ago - 9 years 8 months ago #5713 by c0astl|ght
Bad TIPM or Starter relay port on PT 09 was created by c0astl|ght
Hi,
Thanks in advance to Scanner Danner for allowing me to post my question here. I appreciate it.
I have a 2009 PT Cruiser that will not start. Only starts during bypassing of ignition system.
Well I did the same testlight diagnoses from the video, "How to troubleshoot a starting system (bad ignition switch) - Dodge Neon" on youtube for my mom's PT Cruiser and found that my test light did not light on any of the starter relay ports. Only when I cranked the engine did one port light up - which was the hot wire side. Which is strange. It should be lit all the time even with the engine off.
The ignition swtich wire going in was lit with engine off and during crank the wire going out of ignition switch was lit. So it seems ignition switch is functioning, yet the starter relay port connected to the ignition switch didn't light during crank (I think the wires in-between splice and something is messed up).
Is this a case of a bad TIPM or ground in TIPM or is it the starter relay port issue?
Feedback appreciated. Thanks.
Last edit: 9 years 8 months ago by c0astl|ght.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
9 years 8 months ago #5737 by cheryl hartkorn
Replied by cheryl hartkorn on topic Bad TIPM or Starter relay port on PT 09
im kinda confused? pin 2 on the relay is supposed to only be hot with the key in start position. those Chryslers are bad for the lock actuator for breaking in the column.
9 years 8 months ago #5738 by Chad
Replied by Chad on topic Bad TIPM or Starter relay port on PT 09
Hot in crank/start looks to be normal.
9 years 8 months ago #5752 by Tyler
Replied by Tyler on topic Bad TIPM or Starter relay port on PT 09
Thanks for the diagram, pole71! B)
So, just to be clear, you only have one power feed at the relay with the key in the crank position, correct? By hot wire, are you referring to the load side of the relay (pin 1), or the control side (pin 2)? Just want to be sure about what diagnostic direction to send you in!
Also, did you happen to try connecting your test light to B- and look for grounds at the relay? In the crank position, there should be two - one from the PCM for relay control, and one through the starter solenoid winding (if the winding is intact).
  • c0astl|ght
9 years 8 months ago - 9 years 8 months ago #5794 by c0astl|ght
Replied by c0astl|ght on topic Bad TIPM or Starter relay port on PT 09
Tyler wrote: Thanks for the diagram, pole71! B)
Yes the load side does not light with a test light (grounded) when engine is off but does light when engine is cranked. Something wrong there.
If that is the case it points back to the TIPM. Possible bad ground for TIPM?
The picture is showing a no crank position using a test light:
Tyler wrote: Also, did you happen to try connecting your test light to B- and look for grounds at the relay? In the crank position, there should be two - one from the PCM for relay control, and one through the starter solenoid winding (if the winding is intact).
The "B-" terminal as in from the starter motor? Should I be testing voltage drop from there to the relay grounds? I am going to check all grounds today.
  • c0astl|ght
9 years 8 months ago - 9 years 8 months ago #5795 by c0astl|ght
I've checked the actuator. It is still intact inside ignition.
The starter runs.
Battery is good.
Alternator seems to be fine.
Cables are good.
All the grounds Iv'e checked are good. Still have to look at more hidden grounds though way in the back of the car.
Ignition switch seems good. Power goes in and out the wires.
Starter relay clicks and has continuity.
I can bypass ignition system by taking a screwdriver and touching B terminal and S terminal of starter while key is turned to start car -
or I can use Power Probe to power yellow/grey wire of starter relay port (in diagram I provided) with key turned to start the engine.
I think it's a bad ground with TIPM or Starter Relay port. Still gotta find all grounds.
  • c0astl|ght
9 years 8 months ago - 9 years 8 months ago #5796 by c0astl|ght
Thanks again for taking the time to read this.
I think I found the problem. The ground G104 seems to be very corroded. I don't know how I'm going to get in there:
I guess I'll have to depressurize the fuel system and remove those fuel lines blocking the way to G104. My wiring diagram is showing the ignition switch grounded through the powertrain module control (the antitheft/ park/neutral switch) - which leads to G104. I'm pretty sure that is the reason why my car is not starting.
Anyone know the name of that terminal that is holding the corroded wires together? I may need a new one.
If I cannot remove the fuel lines, would anyone suggest a wrench that can get into places like that?
Thanks again! :D
  • cheryl hartkorn
9 years 8 months ago #5797 by cheryl hartkorn
are you getting a ground from the pcm on pin 5? when in start thatd tell you the inputs are good and the pcm is happy. put the key in run position take a jumper wire and remove the relay from the box and jump terminals 1 and 4 see what happens. the motor should crank
The following user(s) said Thank You: c0astl|ght
  • c0astl|ght
9 years 8 months ago #5800 by c0astl|ght
cheryl hartkorn wrote: are you getting a ground from the pcm on pin 5? when in start thatd tell you the inputs are good and the pcm is happy. put the key in run position take a jumper wire and remove the relay from the box and jump terminals 1 and 4 see what happens. the motor should crank
Yes pin 5 on the pcm does show ground. That's one more thing confirmed as good. Thank you.
I will try out your suggestion with pin 1 and 4, but right now I took out the TIPM.
Would you know how to depressurize the fuel system? I cannot find the fuse for the relay pump according to a 2006 manual when my moms' car is a 2009. If I could depressurize the system I could get to the ground wires that are all corroded. I think that is the source of the problem.
  • cheryl hartkorn
9 years 8 months ago #5801 by cheryl hartkorn
id pull the asd relay and crank it over bypassing the system the way you did. but honestly id just unhook it with a rag over the line if it were me.
  • cheryl hartkorn
9 years 8 months ago #5802 by cheryl hartkorn
if the g104 were bad I would expect to have ,more problems as it shows on the diagram I have its a pcm main ground so id expect a no communication ac compressor not working, radiator fan and a few other things that share that ground
The following user(s) said Thank You: Tyler, c0astl|ght
  • c0astl|ght
9 years 8 months ago #5803 by c0astl|ght
cheryl hartkorn wrote: id pull the asd relay and crank it over bypassing the system the way you did. but honestly id just unhook it with a rag over the line if it were me.
I've got a "ASD Relay Contact PWR Feed" fuse # 18. Is this the one?
If I unhook the line and quickly get a rag in there, will the fuel still drip out of the rag constantly since it's still under pressure? Won't I get a huge spray from the initial disconnect?
  • c0astl|ght
9 years 8 months ago - 9 years 8 months ago #5805 by c0astl|ght
cheryl hartkorn wrote: if the g104 were bad I would expect to have ,more problems as it shows on the diagram I have its a pcm main ground so id expect a no communication ac compressor not working, radiator fan and a few other things that share that ground
I just replaced the fan and radiator for 1600 at the dealership. 2 months later car won't start. Not going back to the stealership.I think the fan still works though. I took it out, however; got me to the starter. :D
I don't know what else to look at. There are grounds G201 and G105 which is inside and Instrument Panel and Side Cowl Panel. Don't know where they are yet. But if I can just go around cleaning grounds that could solve some problems.
It's strange that pin 1 of starter port is not lighting with test light with engine off. It should be always light. So the problem goes back to the TIPM. Possibly a bad ground.
Measuring voltage drop from ( - ) battery terminal to pin 1 starts with:
0.13 v no crank
12.07 v with crank.
Yet there is the TIPM and ignition switch that also share voltage with the starter relay, so how could pin 1 get almost all the voltage from the battery during crank? It should have less volts. I also got about same volts measuring from the ( - ) battery terminal to the fuse inside TIPM during crank. Since the voltage from the ( - ) battery terminal to fuse is almost equal to voltage drop from ( - ) battery terminal to starter relay, that means I got a bad ground somewhere.
And those are not fuel lines over my hands in the pic are they? I think someone just told me they are AC lines. :huh:
I am a noob.
Do you know how to get to the Instrument Panel and the Cowl Panels? Could you tell me what these things would generally be?
Thanks.
9 years 8 months ago #5842 by Tyler
c0astl|ght wrote: Yes the load side does not light with a test light (grounded) when engine is off but does light when engine is cranked. Something wrong there.
No, that's good! That means the TIPM is supplying power to the load side of the starter relay when desired (during cranking). That B+ output is controlled by the TIPM itself, and is NOT a constant feed.
Cheryl is on the right track with the relay testing. I see you found a ground at pin 5 (from the PCM), sweet! If you also have a power on pin 2 with the key in crank, then the relay has everything it needs to work.
9 years 8 months ago #5854 by Noah
Replied by Noah on topic Bad TIPM or Starter relay port on PT 09
c0astl|ght wrote: Thanks again for taking the time to read this.
Thanks again! :D
Check out the wrenches I posted in this thread.
  • c0astl|ght
9 years 8 months ago - 9 years 8 months ago #5861 by c0astl|ght
Tyler wrote: No, that's good! That means the TIPM is supplying power to the load side of the starter relay when desired (during cranking). That B+ output is controlled by the TIPM itself, and is NOT a constant feed.
That sounds good but I saw the video from ScannerDanner on troubleshooting the ignition system on the Dodge Neon and he mentioned that the hot wire has to light the test light at all times.
But if it's a different case for the Chrysler TIPM that would be great! I don't have to worry about a starter relay port defect.
Tyler wrote: Cheryl is on the right track with the relay testing. I see you found a ground at pin 5 (from the PCM), sweet! If you also have a power on pin 2 with the key in crank, then the relay has everything it needs to work.
The thing though is during crank I have no power going to pin 2 during crank. Yet the ignition swtich is lighting for power coming in and out of switch. So I checked the grounds for the ignition switch and it led me to G105 (the one with the corroded eyelet with the picture showing) that seems to be the problem for the start failures.
Currently I got in there with a flexible wrench (thank God I found one) and had to clip the eyelet because I couldn't pull it out far to clean it. I'm going to add new extension of wires by soldering extension wires and then soldering all extensions to new eyelet. That should do the trick.
Last edit: 9 years 8 months ago by Tyler.
9 years 8 months ago #5864 by Tyler
c0astl|ght wrote: That sounds good but I saw the video from ScannerDanner on troubleshooting the ignition system on the Dodge Neon and he mentioned that the hot wire has to light the test light at all times.
Ah yeah, I see why that's confusing! Yeah, the TIPM works differently - it's on the CAN network, and uses a high side driver for the starter relay when it gets the right message over the network.
c0ast|ght wrote: The thing though is during crank I have no power going to pin 2 during crank. Yet the ignition swtich is lighting for power coming in and out of switch. So I checked the grounds for the ignition switch and it led me to G105 (the one with the corroded eyelet with the picture showing) that seems to be the problem for the start failures.
OK, getting somewhere! :cheer: No power at pin 2, but you DO have power at pin 4, pink/light blue wire, at the ignition switch in crank? If that's true, then you're looking at an open wire between the ignition switch and the starter relay.
Any remote start, or other wiring messed with in the steering column? If not, then you're down to tracing that circuit 'till you find the open. The OE diagram shows C104 in between the ignition switch and the relay, I'll see if I can locate that tomorrow. If you could get to that connector easily, you could probe it and tell which direction to look for the wiring problem.
  • c0astl|ght
9 years 8 months ago #5867 by c0astl|ght
Tyler wrote: OK, getting somewhere! :cheer: No power at pin 2, but you DO have power at pin 4, pink/light blue wire, at the ignition switch in crank? If that's true, then you're looking at an open wire between the ignition switch and the starter relay.
I only have power going to pin 1 during crank. When the engine is off all pins are not showing power.
But when I put power to pin 3/4 with the Power Probe the car starts up again. So I guess from the end-side control of starter relay to the starter motor is good. It's just the stuff before pin 3/4 to the fuse that is off at the moment. I even have weird voltage drop(during crank) between fuse and starter relay.
Tyler wrote: Any remote start, or other wiring messed with in the steering column? If not, then you're down to tracing that circuit 'till you find the open. The OE diagram shows C104 in between the ignition switch and the relay, I'll see if I can locate that tomorrow. If you could get to that connector easily, you could probe it and tell which direction to look for the wiring problem.
No remote start and I didn't touch any wiring inside the steering column. Just one day after replacing fan and radiator, the car stopped working. I live in Alberta, Canada and when it happened it was around December.
Thanks for the help though. I will check out the diagrams again as well. :D
9 years 8 months ago #5909 by Tyler
c0astl|ght wrote: I only have power going to pin 1 during crank. When the engine is off all pins are not showing power.
OK, so we need to pursue the ignition switch (or the wiring), then. There should absolutely be power at pin 2 at the starter relay during cranking, and there isn't.
Earlier you mentioned checking the ignition switch - are you positive you had power at the pink/light blue wire?
If you wanted to prove that missing power at pin 2 of the starter relay is the problem, you could plug the starter relay partially into it's socket in the TIPM and touch pin 2 with a test light connected to B+ with the key in the crank position. This will simulate the power feed from the ignition switch, and the engine should crank.
  • c0astl|ght
9 years 8 months ago #5954 by c0astl|ght
Tyler wrote: OK, so we need to pursue the ignition switch (or the wiring), then. There should absolutely be power at pin 2 at the starter relay during cranking, and there isn't.
Yes. I checked that pin like 10 times. Every time the pink/blue wire lit during crank. Since no power gets to pin 2 I believe it is a wiring problem with the ignition switch as even the wires leading to ground for the ignition switch were corroded (in the picture I provided earlier. They are all blue).
Tyler wrote: If you wanted to prove that missing power at pin 2 of the starter relay is the problem, you could plug the starter relay partially into it's socket in the TIPM and touch pin 2 with a test light connected to B+ with the key in the crank position. This will simulate the power feed from the ignition switch, and the engine should crank.
Definitely I will do this wire jump as well if it doesn't start tomorrow.
I just soldered on new wires into a new eyelet:
Tomorrow I will put everything back together and see if it starts normally. The new wires are much cleaner than before. This has to work.
Time to create page: 0.477 seconds
