[FIXED] Bad TIPM or Starter relay port on PT 09
- cheryl hartkorn
- Thank you received: 130
- c0astl|ght
cheryl hartkorn wrote: im confused. first you said you had power at pin 2 then nothing coming out of the tipm. the last post you said you only had power on pin 1 which comes from the tipm, then nothing on pin 2 from the ignition switch. that means the tipm is good. did you try swapping relays? in one post tyler noted you had all the things for the relay to work.
I will show a picture to illustrate:
The test light grounded:
- lights up both fuses. Both fuses are good.
- lights up the red wire going into ignition switch and the pink/blue wire going out of the ignition switch. Ignition switch seems good.
- does not light the red/blue wire going to starter relay (pin 2) from the ignition switch. There are corroded grounds for the ignition switch.
Now on the other side, the test light grounded:
- lights up pin 1 of the starter relay only when cranked.
Tyler said this is normal for pin 1 to only light during crank for the Chrysler TIPM. So it seems the starter relay is good.
The problem is somewhere between the ignition switch and the starter relay.
It had to be those grounds. Right now it's late to put everything back together outside so tomorrow it should all work (knock wood).
c0astl|ght wrote: I will show a picture to illustrate:
Thanks for this, sir! I'm sorry, I really don't mean to nag so much. :lol:
The grounds... I agree, that ground you found didn't look great, but that still wouldn't prevent power getting from the ignition switch to the starter relay.
- c0astl|ght
The grounds... I agree, that ground you found didn't look great, but that still wouldn't prevent power getting from the ignition switch to the starter relay.As far as I know, there's nothing 'intelligent' about the ignition switch that'd require a ground to operate.
No please don't be sorry! I welcome your feedback!
I'm the student here and it isn't worth advising me if I do not listen. Your feedback is important.
I'm grateful to everyone for helping me!
I just hope the grounds fix the problem. If not I will use your suggestion as well as Cheryl's suggestion from earlier tomorrow when I put everything back together.
This has to work though. This car has been out of commission for 3 months and I've been working on it for about 1 month and a half.
- c0astl|ght
Tyler wrote: No, that's good! That means the TIPM is supplying power to the load side of the starter relay when desired (during cranking). That B+ output is controlled by the TIPM itself, and is NOT a constant feed.
Well the engine did not start with the new soldered connections. I put everything back together and am going to do the tests you and Cheryl suggested. My mom is coming back and we will do some of those tests.
Just to clarify though, the B+ output is the same location as the fuse right? I don't see any other outlets on the TIPM.
Thanks again.
- c0astl|ght
cheryl hartkorn wrote: are you getting a ground from the pcm on pin 5? when in start thatd tell you the inputs are good and the pcm is happy. put the key in run position take a jumper wire and remove the relay from the box and jump terminals 1 and 4 see what happens. the motor should crank
Hi Cheryl. It worked! Thank you.
With the starter relay out and a wire between pin 1 and 3/4 of the relay port the car started.
Sorry I couldn't do these tests earlier. I had the TIPM already out when you made this suggestion and I was in the middle of soldering a new eyelet for ground G104. Now everything is back together.
I guess that means my starter relay port is working though. Now it's probably still the ignition side that's at fault.
I'm trying to find ground G201 related to the ignition switch on the PT but that will take some time. I found all the other grounds related to the ignition switch (G100, G102, G104, G105). I re-soldered G104 as you can see in the picture above (going to redo it again with better eyelets this time). I cleaned up G100, G102, and G105.
Now to find G201. The last ground related to the ignition switch. This one is a bit tricky to find.
It has to be this last ground hey?
c0astl|ght wrote: Just to clarify though, the B+ output is the same location as the fuse right? I don't see any other outlets on the TIPM.
I'm not positive I understand the question... The B+ output comes from the TIPM, yes, just from a solid state device on the circuit board. There is no fuse for the load side output, as far as we're concerned. Aside from the circuit board itself
Sweet! That clears the load side of the TIPM.
Could you post the diagram you're using to find the grounds? Just so we can follow your line of thought.
I'm still not convinced it's a ground issue.
If you wanted to prove this, you could run a jumper (or several chained together, as needed) from pin 4 at the ignition switch to pin 2 at the starter relay. OR, just use a test light connected to B+ on pin 2 of the starter relay with the relay partially installed. Either way, the engine should crank with the key as normal.
- c0astl|ght
Tyler wrote: I'm not positive I understand the question... The B+ output comes from the TIPM, yes, just from a solid state device on the circuit board. There is no fuse for the load side output, as far as we're concerned. Aside from the circuit board itself
So how do I find B+ on the TIPM? If I place one end of the test light on pin 2 of the starter relay, does the other end of the test light touch the B+ terminal? Can't find the B+:
Tyler wrote: Could you post the diagram you're using to find the grounds? Just so we can follow your line of thought.
I'm still not convinced it's a ground issue.We know there's power coming out of the ignition switch (it's working), but it's not getting to the starter relay. There's some kind of poor connection in between.
Well it's good the load side of TIPM of starter relay is good. More of a relief and can focus backwards now.
I have alot of wiring diagrams that are related to the ignition switch so let me know if you would like all of them (like 10 pages). But here are 2 of them:
Is it possible that with my fan out of the car it is also stopping the car from starting? I got 2 relays on that fan when I took it out.
I think tomorrow morning I will reinstall fan and clip it back into the circuit.
I will also get a test light between pin 4 of ign. switch to pin 2 of starter relay tomorrow. I see what you mean now.
c0astl|ght wrote: So how do I find B+ on the TIPM? If I place one end of the test light on pin 2 of the starter relay, does the other end of the test light touch the B+ terminal? Can't find the B+
Ahhhhh OK, I getcha now!
I love your test light drawing, BTW
I forget that OE diagrams like to break stuff up like that. :blush: Not that OE diagrams are bad!
So none of those grounds go directly to the ignition switch, then? Then I think you're safe to skip the ground checks and go directly to the ignition switch wiring. A problem with any of those grounds is not going to prevent the ignition switch from working.
You know, I've been trying to put the fan/radiator thing together with this symptom ever since you mentioned it, and I've got nothing so far. :blush: I thought about the starter solenoid wire getting damaged, but we now know that isn't true, since you got it to start by bypassing the starter relay.
If needed, we can try to ID relays that came out with the fan. I've done fan replacements on older PT Cruisers, but none of those had any relays attached. This newer one may be different.
I think we're close to the solution on this one.
- c0astl|ght
Tyler wrote: Ahhhhh OK, I getcha now!
You can clip the test light any B+ source you can find, doesn't necessarily have to be on the TIPM. The battery itself would be easiest.
I love your test light drawing, BTWBetter than anything I could do.
Ok ~ ~ ~ I get it now! Lol. I'm such a noob. So B+ is just anything positive on the circuit. The battery. :lol:
Thanks. My drawings is not too bad.
Tyler wrote: So none of those grounds go directly to the ignition switch, then? Then I think you're safe to skip the ground checks and go directly to the ignition switch wiring. A problem with any of those grounds is not going to prevent the ignition switch from working.
Yea with all the diagrams I checked under the ignition/fuel system wiring, nothing goes directly to ground. It seems to go through the PCM/anti-theft first.
But I might have some bad news. Hopefully I didn't short the starter relay port because now putting a wire between pin 1 and 4 won't work anymore. It did earlier this morning when I went to test again and then decided to take a shortcut and place the wire between pin 1 and 2 of the starter relay to send power to 2 and see what happens. Nothing. Then I went back to pin 1 and 4 and now it wont start.
I think I just blew something up in there by going 1 to 2. I could redo 1 and 4 again but is this something to worry about?
And I put the fan back in all connected and still nothing.
If the ignition switch is at fault, that would be strange because I tested like 5 or 10 times and the power does go in and out the ignition switch. The power coming out somehow doesn't reach pin 2 of the starter relay. Probably wiring but I'm at a loss. I just cleaned all grounds I could find and replaced 1 of the grounds. Still one more ground to find though. Still can't find it. Could it still be possible the ignition switch is bad even when power goes in and out?
Anyhow, thanks again for all your help. I really appreciate it.
c0astl|ght wrote: But I might have some bad news. Hopefully I didn't short the starter relay port because now putting a wire between pin 1 and 4 won't work anymore. It did earlier this morning when I went to test again and then decided to take a shortcut and place the wire between pin 1 and 2 of the starter relay to send power to 2 and see what happens. Nothing. Then I went back to pin 1 and 4 and now it wont start.
Thanks again for all your help. I really appreciate it.
Really? :huh: Shorting between pin 1 and 2 of the starter relay shouldn't have fried anything...
Now that you've got the fan back in, can you go back over the starter relay pins with a test light? As always, we want power on pins 1 and 2, and ground on pins 4 and 5. Relay out, key cranking. Get back to me with those readings, and we'll go from there!
- c0astl|ght
Tyler wrote: Really? :huh: Shorting between pin 1 and 2 of the starter relay shouldn't have fried anything...
Alright. I checked the starter relay with the test light again.
With engine off I checked for grounds and got a green light for pin 4 and 5 only. I didn't crank the engine and check again (which I should have done). I also noticed that with the engine off and checking grounds for pin 4 and 5, pin 5 shows a dim light while pin 4 is bright.
With engine off I checked for power and got no power at any of the pins of starter relay. With the engine cranked I got a red light for pin 1 only (not as bright as pin 4 showing green).
So in hindsight I forgot to crank during ground test only to check the lights again, but my assistant/mom is gone now. I'll have to find a new assistant or wait till she gets back today. But so far it seems like I haven't fried anything as everything is the same as before as far as ground lights and power lights lighting up.
- cheryl hartkorn
c0astl|ght wrote: Alright. I checked the starter relay with the test light again.
OK, I like those readings!
I dunno if it'd help at all, but you can watch this ScannerDanner video for possible ways to do the testing yourself. The video is technically about a transmission problem, but the methods for testing the relay itself are still applicable.
Not trying to rush you or anything! I just know how much I hate waiting around for an assistant.
- c0astl|ght
OK, I like those readings!Well, it sounds like we're still where we were before, anyway. Seeing power on pin 1 makes me feel a lot better. :lol:
Thank you Tyler and Cheryl. I can't thank you enough.
I'll also check grounds again during crank.
I've got a feeling the problem is between the ignition switch and the starter relay. We'll find out soon.
Thanks again!
Oops. I mean I will try your suggestion Tyler and stick back probe into ignition switch and other at the starter relay pin 2.
- c0astl|ght
Looks like this might end in the same way as the video. I'm hoping not because I will have to go thru wire harnesses - which I have no experience in. That may have to go to the dealership...
So I did the wire jump test again from pin 1 to 4 and I got the car to start.
I also wrapped some wire around my starter relay and pushed it in partially to pin 2 (red/blue) of starter relay port and took the other end of the wire and stuck it to the ignition switch pin 4 (pink/blue) with the back probe in while engine cranked. Car started! That was amazing!
So I'm thinking it's a wire between ignition switch and the starter relay now.
Funny thing is now I found a green light on pin 1 of starter relay with engine off (connected to ( + )) using the test light.
But when I put the test light to the same pin with the engine cranked changing to ground ( - ), I see red light for power (which is still normal for test light grounded).
So I don't know if that is something to be concerned about.
Also my ground eyelet I previously repaired is now on a new ground sharing it with another eyelet. Lost the bolt during re-installation. Fell down somewhere. Is this okay? No harm sharing ground with another eyelet right? While the eyelet was sharing new ground I did these tests and the car still started.
So it's safe to say the wiring is the problem hey? between the ignition switch and the starter relay.
c0astl|ght wrote: I also wrapped some wire around my starter relay and pushed it in partially to pin 2 (red/blue) of starter relay port and took the other end of the wire and stuck it to the ignition switch pin 4 (pink/blue) with the back probe in while engine cranked. Car started! That was amazing!
Sweet! :woohoo: Very happy to hear this. Not only does it prove a wiring problem, but it also proves that nothing got harmed earlier.
Are you using an incandescent test light, or some kind of logic probe? Power Probe? :huh: Nothing wrong with those at all, just trying to make sense of your observations. Where are you seeing the 'green light'?
I think you're OK? As long as your connections are solid, then I don't see a problem.
No way! You can totally handle this.
This is what we're after. C104, a connector that has our suspect wire in it. I'll do some research tomorrow and find where C104 is, exactly. Once we find C104, we can test for power there during cranking (with the jumper wire removed). If we find it, that tells us to work towards the starter relay. If we don't, that tells us to work towards the ignition switch.
- c0astl|ght
Tyler wrote: Sweet! :woohoo: Very happy to hear this. Not only does it prove a wiring problem, but it also proves that nothing got harmed earlier.
Thank the Lord! (I am not Christian but I believe in da God
)Now I just gotta find that bolt stuck down there somewhere.
Tyler wrote: Are you using an incandescent test light, or some kind of logic probe? Power Probe? :huh: Nothing wrong with those at all, just trying to make sense of your observations. Where are you seeing the 'green light'?
I was using a test light only for checking power and ground when you requested I check the starter relay pins 1, 2, 4, and 5. This is it but I need to take a new picture of it testing relay:
The test light when hooked to B+ will turn green when put on B-. So with it hooked to B+ and then putting test light to pin 1, 4, and 5, it turned green. Very dim for pin 1 (barely noticeable), dim for pin 5, and bright for pin 4. It should have only been green for pin 4 and 5 as I found earlier but since pin 1 is very dim I barely noticed it the whole time lighting green - showing ground. That's when test light is hooked up to B+.
During crank though, pin 1 does not show a green light anymore.
However it goes back to normal when the test light is hooked to B- and I touch pin 1 of starter relay. It turns bright red during crank.
Nice. :lol: I just have to make do until I find a new bolt or the old one later on. Perhaps I should leave it alone. So much work down there. Lol.
No way! You can totally handle this.Check it out:
Oh man. This is going to be something.
I guess I could try. I already soldered on 8 connections total so far.
Alright. I'll give it a try. I'll look up c104 as well. Thanks again man.
I owe you a beer or something.
- c0astl|ght
I also have all the diagrams from locating C104. I know where some of them already are but unsure of some other locations.
I'm guessing the next step is to check voltage drop on each side and replace the wire on the bad side right? I hope I don't have to replace wire along side steering column. That will be like facing Mike Tyson in his prime. :lol:
- c0astl|ght
Gotta pay it forward.
Don't fall victim to social engineering.
