F150 No code intermittent misfire issues
- 52Tele
- Thank you received: 5
- 52Tele
I thought I saw a way to message individual members on here is that a possibility?
It used to be. I think that feature was removed during an update to the site. You are welcome to send me an email if you like.Hello Noah
- 52Tele
- 52Tele
This video really helped me understand the PIDs used for VVT diagnosis on Ford engines.
- 52Tele
- 52Tele
- 52Tele
Noah, Tyler and others on forum would know far more on vvt than me. I know they recommend oil changes as stated by manufacturers. Looking back, your scanner said both banks lean at 3500 rpm, bank 2 far leaner than bank 1. Just saying.
Bill would I be able to send you a email?
- bills4065
- Thank you received: 17
Put F150 in subject line, so I know who sent it. Thanks.
- 52Tele
One interesting thing that has changed. I did an oil change and ran some Marvel mystery oil in my fuel and oil. Now at 3500 rpm these are the consistent results I'm getting.
At 3500 long terms at or around zero for both banks. The screenshot I took 2 days ago shows Short term bank 1 -0.78 and bank 2 30.47.
Now the interesting part. That bank 2 number builds to that level at 3500 rpm. If I go past 3500 about when I get to 3800 bank 2 short term drops and equals out close to what bank 1 is at the time.
So my questions are would those results be symptoms of stuck closed injectors on bank 2 that re-open when I go past 3500 rpm?
Or can the same thing happen with the VCT system.
If I'm thinking about this wrong let me know. Couldn't the VCT system be keeping the valves open incorrectly which would then call for more fuel to be injected? And then once the rpm is higher the solenoids aren't sticking as bad.
Most of the misfires occur on cylinder 6 so even before I was on the forum I swapped the cylinder 6 injector to the opposite bank with not much change.
I hope that today after work I'll have time to swap all injectors from bank 2 over to bank 1 and see if the issue follows.
Would yall agree that is a good next step until i can get another fuel pressure tester?
- bills4065
www.scannerdanner.com/forum/post-your-re....html?start=40#64954
Those values seem pretty normal for Ford AFR's. For reference, this is off a known good 2011 F-150 5.0L at idle and during a WOT run:
HPTuners displays the AFR's in mA, but the Autel shows uA, so there'll be a little mental math involved. .027 mA would be 27 uA.
I find that fluctuations of +/- 100 uA is pretty normal for those systems. That's not a rule, just a trend I've noticed.
As long as the commanded equivalence ratio and the actual generally agree, I wouldn't sweat the AFR's too much. Here's another capture of a test drive with the equivalence ratios for both banks, plus a math channel of the difference between commanded and actual. The only real difference comes during decel fuel cut off:
- bills4065
Yep, looks good to me. Matches what I saw in that 2011 capture I posted. Those values show good power enrichment at WOT.Thanks Tyler- I was looking at his beginning and after wide open throttle posted by 52 Tele. At your convenience, look at his sorry this is after screenshots. At 3947 rpm was his lowest lambda number for bank one .72, bank 2 .76 At 5508.25 rpm the lambda number was .83 for both banks.
- 52Tele
bank 2
short term was 25
long term was -.08
bank 1
Short term -3.1
Long-term-.08
- 52Tele
- 52Tele
- 52Tele
- 52Tele
